| precisionchassis |
Nov 27 2016, 01:09 PM
Member ![]() ![]() Group: Members Posts: 99 Joined: 26-July 10 From: Gilbert, AZ Member No.: 11,979 Region Association: Southwest Region |
The last time I did a Subaru powered 914, I used a Boxster 5 speed transaxle. and had an extra pair of axle shafts made as a spare. I never needed them and I've since closed down my shop, so I have these axles available for anybody interested.
For those that don't know, the Boxster (base model) and the 914 share the same rear wheel bearings. What this means is that you can use the Boxster wheel hub, and stub axle in the 914 trailing arm, which also means you can use the Boxster CV joints IF you have these custom axle shafts to go with them. What you also might not know is that the Boxster cable shifter will work in the 914 chassis without the need for custom cables. Also, a number of Audi engines bolt directly to the Boxster transaxle without the need for any adapter plate or custom flywheel. Asking $200 for this pair of axles. (IMG:http://www.914world.com/bbs2/uploads_offsite/i180.photobucket.com-11979-1480273745.1.jpg) Anyone interested should contact me via email at precisionchassis@gmail.com for the fastest response. |
| flmont |
Nov 27 2016, 09:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 881 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region
seems as tho this set-up would be a money maker,..subie engine and a boxter trans that bolts to a 914 with little to no mods..???
| mepstein |
Nov 28 2016, 06:07 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,918 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
seems as tho this set-up would be a money maker,..subie engine and a boxter trans that bolts to a 914 with little to no mods..??? But a big price tag compared to a suby engine and a suby trans. Both need custom axles but the boxter trans still needs an adapter to mate to the suby engine. That's a pricey mod compared to bolting on a stock mt5 suby trans. |
| Chris H. |
Nov 29 2016, 05:57 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,106 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
seems as tho this set-up would be a money maker,..subie engine and a boxter trans that bolts to a 914 with little to no mods..??? But a big price tag compared to a suby engine and a suby trans. Both need custom axles but the boxter trans still needs an adapter to mate to the suby engine. That's a pricey mod compared to bolting on a stock mt5 suby trans. True if you are doing a Subaru conversion, but if you want to do an Audi conversion this would be a very inexpensive and easy way to go. The 5 speed boxes are cheap and plentiful and you don't have to measure for cables and stuff. Just buy the Boxster ones, along with the shifter. The hydraulic clutch line would probably be the right length too. You could also adapt the Boxster center console and move the e-brake to the middle if you wanted to get crazy. |
precisionchassis FS: Custom axles for Boxster 5 speed transaxle in 914 Nov 27 2016, 01:09 PM
mepstein That's a neat part. Sort of a missing link. So... Nov 27 2016, 02:02 PM
Chris914n6 What year Boxsters?
I looked at one at the wrecke... Nov 27 2016, 05:22 PM
gearjam Sent PM Nov 30 2016, 08:22 PM
Tigre81 If they are still available, I'll take them..... Dec 4 2016, 10:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 22nd September 2026 - 07:06 PM |
