> push button for starter question
rosenfe
post Nov 26 2016, 01:59 PM
on my 73 2.0,i would like to put a push button for starting.in my reading,i understand that i can put button between hot lead and yellow lead at solenoid.is this correct,if so what is best way to get buttons up to dash from solenoid?
screenguy914
post Nov 29 2016, 06:32 PM
The crank position flows more current through the switch contacts then other electrical loads, and it fails sooner than the On or Accessory switch positions.
Why not? What's the cost of a new ignition switch/steer. wheel lock? Autozone ...... Autozone wants $800.00 :-O.
Just need the contact section? That's only about $30, but not sure you want to go to the trouble of accessing it (pretty straightforward though).
I'm planning on installing a separate crank button.
Sherwood
rosenfe   push button for starter question   Nov 26 2016, 01:59 PM
McMark   Big red wire and big yellow wire at the ignition s...   Nov 26 2016, 02:06 PM
porschetub   Big red wire and big yellow wire at the ignition ...   Nov 26 2016, 04:15 PM
The Cabinetmaker   Nuff said!   Nov 26 2016, 02:53 PM
jim_hoyland   Interesting how these start buttons have evolved.....   Nov 26 2016, 09:55 PM
Bartlett 914   Really old cars had foot switches mounted on the f...   Nov 27 2016, 01:50 PM
wndsrfr   Really old cars had foot switches mounted on the ...   Nov 27 2016, 01:57 PM
The Cabinetmaker   Actually, they were located to the right of the ga...   Nov 27 2016, 02:00 PM
ClayPerrine   Actually, they were located to the right of the g...   Nov 28 2016, 06:21 PM
timothy_nd28   They make for great garage door switches   Nov 27 2016, 02:08 PM
Elliot Cannon   Our 1953 Nash had the starter switch on the floor,...   Nov 27 2016, 06:46 PM
RickS   on my 73 2.0,i would like to put a push button fo...   Nov 27 2016, 11:37 PM
BigFour1973   on my 73 2.0,i would like to put a push button f...   Nov 28 2016, 06:38 PM
anderssj   Why couldnt you have the push button inline with...   Nov 29 2016, 04:48 PM
7TPorsh   Yes I want to do this too. No more bent keys. .   Nov 28 2016, 07:03 PM
Rand   I know it sounds hackish to some, but I've put...   Nov 28 2016, 07:46 PM
iamchappy   My old Mini had it on the floor by the seat...   Nov 28 2016, 07:51 PM
KELTY360   Old technology. My '47 Lincoln had a push butt...   Nov 28 2016, 11:05 PM
screenguy914   The crank position flows more current through the ...   Nov 29 2016, 06:32 PM
patssle   I have a push button on mine and have found it ext...   Nov 29 2016, 06:35 PM
matthepcat   ^^ My 914-V8 had that same type ^^ It never let m...   Nov 29 2016, 06:40 PM
Mark Henry   My gas snow blower had a push start..... :lol: H...   Nov 29 2016, 07:17 PM
naro914   Papa Smurf has a push start and two switches: one ...   Nov 29 2016, 07:36 PM
jcd914   I did not see this mentioned, so ... One of the t...   Nov 29 2016, 08:02 PM
WLD419   I put starter button in my dash , only works with ...   Nov 29 2016, 09:10 PM
- Lo-Fi Version Time is now: 7th December 2025 - 09:32 PM
