thomasotten |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,565 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 ![]() |
I am curious as to what kind of oil cooler setup is required or recommended
when installing a stock 74-77 2.7 911 engine. Use stock t-stat control valve, stock cooler? Any past experience would be appreciated. |
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,454 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
I am curious as to what kind of oil cooler setup is required or recommended when installing a stock 74-77 2.7 911 engine. Use stock t-stat control valve, stock cooler? Any past experience would be appreciated. Key is if you will be running it on track. Half hour DE's put a lot of heat into that 8 quarts of oil & you'll need the front cooler. If only street driving you're prolly OK with stock. |
Lo-Fi Version | Time is now: 15th July 2025 - 03:42 AM |
