| tazz9924 |
Nov 19 2016, 04:33 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 755 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Ok, So, i have an ej205 in my car and until recently ive had just a hose going from one end of the heater pipes to the other. But lately i got the big idea to move to the 20th century and so i added a heater core up front. this meant ~ 20' of 5/8" heater hose (autozone was just thrilled) filled the hoses with water added a bleeder and BAM heat......Or so i thought. My car ran consistently 170-180 now at idle im around 207-208 and it climbs to 230 before im too scared to drive more. ive been attempting to bleed it for three days scolding myself all along they way. What have i done wrong or what can i try, ive been on hills stopped suddenly and swerved hardcore. is it possible that now my car just runs hotter or is there a magic trick for removing air please help!
| 76-914 |
Dec 2 2016, 07:20 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,911 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Take a pic of your hose routing in the engine bay. Be thorough. Include pic's showing your reservoir and/or expansion tank. Show the high points and low points. A drawing is 2 dimensional and emblematic at best. Where is your bleed located in the front trunk?Did you do the build yourself and this is the 1st overheating problem or did someone else build it and since you worked on it the overheating problem began? Once we get this straightened out you can reconnect your heater but you will need the part shown in my previous response. You can pm me if you need. (IMG:style_emoticons/default/beerchug.gif)
tazz9924 Cooling problems in the winter. Nov 19 2016, 04:33 PM
matthepcat I suggest adding some pictures of your system. Har... Nov 19 2016, 05:13 PM
tazz9924 sorry for the crappy photo. then the heater core i... Nov 19 2016, 05:57 PM
Andyrew Betcha its air. Nov 19 2016, 06:00 PM
matthepcat ^^ I agree ^^
You're introducing more tubing... Nov 19 2016, 06:17 PM
tazz9924
^^ I agree ^^
You're introducing more tubin... Nov 19 2016, 07:40 PM
zipedadoo Make sure your heater core and hoses are not block... Nov 19 2016, 07:09 PM
914_teener
Make sure your heater core and hoses are not bloc... Nov 19 2016, 07:44 PM
tazz9924 so its basically this
Nov 20 2016, 12:09 AM
matthepcat What ports are you pulling hot water off the engin... Nov 20 2016, 03:12 AM
zipedadoo That looks like the same way I ran my heater.
If... Nov 20 2016, 08:55 AM
tazz9924
T... Nov 20 2016, 11:26 AM
zipedadoo My funnel/bleeder set up. This way I get a real hi... Nov 20 2016, 09:05 AM
tazz9924 where can i get a 4 way valve? all my hoses r 5/8
... Nov 20 2016, 11:29 AM
zipedadoo I found the 4 way valve on Amazon. They sell a cab... Nov 20 2016, 04:56 PM
76-914 You need one of these:
the other side:
and y... Nov 20 2016, 05:39 PM
tazz9924 I removed the heater because i couldn't bleed ... Dec 2 2016, 05:53 PM
rhodyguy Have you bought the parts that were suggested? You... Dec 2 2016, 06:52 PM
tazz9924
Have you bought the parts that were suggested? Yo... Dec 2 2016, 07:46 PM
tazz9924
Take a pic of your hose routing in the engine bay... Dec 2 2016, 07:49 PM
76-914 If nothings changed then I'd verify the temp y... Dec 3 2016, 08:57 AM
tazz9924
If nothings changed then I'd verify the temp ... Dec 3 2016, 02:17 PM
tazz9924 Ok so the hoses r nothing special the go from the ... Dec 3 2016, 03:28 PM
tazz9924 more pics Dec 3 2016, 03:29 PM
904svo Due to the way Subaru operates the thermostat it m... Dec 3 2016, 04:14 PM
tazz9924
Due to the way Subaru operates the thermostat it ... Dec 3 2016, 06:31 PM
76-914
Due to the way Subaru operates the thermostat it... Dec 3 2016, 07:33 PM
tazz9924
[quote name='tazz9924' post='2430031' date='Dec 3... Dec 3 2016, 10:44 PM
xmotox hey taz i live in lakewood and would like to sea y... Dec 4 2016, 12:55 AM
76-914 Take him up on that offer Tazz. Two head are bette... Dec 4 2016, 08:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 8th July 2026 - 03:34 AM |
