> Cooling problems in the winter., i may have goofed
tazz9924
post Nov 19 2016, 04:33 PM
Ok, So, i have an ej205 in my car and until recently ive had just a hose going from one end of the heater pipes to the other. But lately i got the big idea to move to the 20th century and so i added a heater core up front. this meant ~ 20' of 5/8" heater hose (autozone was just thrilled) filled the hoses with water added a bleeder and BAM heat......Or so i thought. My car ran consistently 170-180 now at idle im around 207-208 and it climbs to 230 before im too scared to drive more. ive been attempting to bleed it for three days scolding myself all along they way. What have i done wrong or what can i try, ive been on hills stopped suddenly and swerved hardcore. is it possible that now my car just runs hotter or is there a magic trick for removing air please help!
post Dec 3 2016, 08:57 AM
If nothings changed then I'd verify the temp your seeing. If the temp shown is correct check the thermostat, verify the 1/8' hole in it is open. Flush the block and the radiator with a garden hose to verify flow. Install a vent on the high side of the radiator outlet hose. Some people have tapped the outlets on the engine and installed a plug to vent but I didn't find that necessary. Again, more detailed pic's will narrow it down. (IMG:style_emoticons/default/beerchug.gif)
tazz9924   Cooling problems in the winter.   Nov 19 2016, 04:33 PM
matthepcat   I suggest adding some pictures of your system. Har...   Nov 19 2016, 05:13 PM
tazz9924   sorry for the crappy photo. then the heater core i...   Nov 19 2016, 05:57 PM
Andyrew   Betcha its air.   Nov 19 2016, 06:00 PM
matthepcat   ^^ I agree ^^ You're introducing more tubing...   Nov 19 2016, 06:17 PM
tazz9924   ^^ I agree ^^ You're introducing more tubin...   Nov 19 2016, 07:40 PM
zipedadoo   Make sure your heater core and hoses are not block...   Nov 19 2016, 07:09 PM
914_teener   Make sure your heater core and hoses are not bloc...   Nov 19 2016, 07:44 PM
tazz9924   so its basically this   Nov 20 2016, 12:09 AM
matthepcat   What ports are you pulling hot water off the engin...   Nov 20 2016, 03:12 AM
zipedadoo   That looks like the same way I ran my heater. If...   Nov 20 2016, 08:55 AM
tazz9924   That looks like the same way I ran my heater. T...   Nov 20 2016, 11:26 AM
zipedadoo   My funnel/bleeder set up. This way I get a real hi...   Nov 20 2016, 09:05 AM
tazz9924   where can i get a 4 way valve? all my hoses r 5/8 ...   Nov 20 2016, 11:29 AM
zipedadoo   I found the 4 way valve on Amazon. They sell a cab...   Nov 20 2016, 04:56 PM
76-914   You need one of these: the other side: and y...   Nov 20 2016, 05:39 PM
tazz9924   I removed the heater because i couldn't bleed ...   Dec 2 2016, 05:53 PM
rhodyguy   Have you bought the parts that were suggested? You...   Dec 2 2016, 06:52 PM
tazz9924   Have you bought the parts that were suggested? Yo...   Dec 2 2016, 07:46 PM
76-914   Take a pic of your hose routing in the engine bay....   Dec 2 2016, 07:20 PM
tazz9924   Take a pic of your hose routing in the engine bay...   Dec 2 2016, 07:49 PM
76-914   If nothings changed then I'd verify the temp y...   Dec 3 2016, 08:57 AM
tazz9924   If nothings changed then I'd verify the temp ...   Dec 3 2016, 02:17 PM
tazz9924   Ok so the hoses r nothing special the go from the ...   Dec 3 2016, 03:28 PM
tazz9924   more pics   Dec 3 2016, 03:29 PM
904svo   Due to the way Subaru operates the thermostat it m...   Dec 3 2016, 04:14 PM
tazz9924   Due to the way Subaru operates the thermostat it ...   Dec 3 2016, 06:31 PM
76-914   Due to the way Subaru operates the thermostat it...   Dec 3 2016, 07:33 PM
tazz9924   [quote name='tazz9924' post='2430031' date='Dec 3...   Dec 3 2016, 10:44 PM
xmotox   hey taz i live in lakewood and would like to sea y...   Dec 4 2016, 12:55 AM
76-914   Take him up on that offer Tazz. Two head are bette...   Dec 4 2016, 08:57 AM
- Lo-Fi Version Time is now: 8th July 2026 - 03:32 AM
