porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,920 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Car has very firm ride in the front,I have Bilstein inserts in Boge struts but the ride is really bone jarring to the point that I have disconnected the swaybar to try and soften it up a little which it did.
Previous to unhooking the swaybar I couldn't even bounce the front of the car with my own weight,needless to say the car isn't that nice to drive (IMG:style_emoticons/default/sad.gif) . Is there an easy way to check the size,are they marked on the ends? I strongly suspect they are too larger diameter or not setup right (indexing ?) maybe,any helpful suggestions guys,thanks in advance. PS front is only lowered a small amount. |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
IIRC they were originally stock only 16 mm front & 15 mm rear on both the /4 & -6, or I may have that Bass-ackwards.
FYI - My `73 were stock, Boge struts with classic Koni Sport inserts, lowered an inch & all front bushings replaced back in 1980-83 resto/rebuild, & it rode fine without any harshness nor bump steer. So maybe the bushings noted above & proprer smaller sized sway bar with smooth yours out? (IMG:style_emoticons/default/confused24.gif) Here are the back-in-the-day Road & Track spec for my 73 2.0, but it doesn't list the sway/anti-roll bar sizes.... ![]() Good Luck! (IMG:style_emoticons/default/beerchug.gif) /////// |
Lo-Fi Version | Time is now: 7th September 2025 - 08:43 AM |
