Off idle bog - previously running well, '74 D-Jet FI |
Nogoodwithusernames |
Dec 2 2016, 01:37 PM
Member Group: Members Posts: 239 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
Hey guys, so after replacing all my fuel lines and vacuum lines everything was going great until the fuel tank settled down a bit and pinched the return line somehow causing excessive fuel pressure and popping a line off. Been a while since that but finally got new lines (again) under the tank (I even went stainless braided to help avoid kinks and such) but now I have a major bog as soon as I come off idle. Idle does wander a bit between 1000 and 1500 so I'm thinking vacuum leak but I didn't have any problems previously until finally starting the motor again after re-redoing the front fuel lines.
All vacuum lines are connected, aka no loose vacuum hoses anywhere. Fuel is right at 28 or 29PSI. This is all on a 2l D-Jet system. |
Dec 5 2016, 10:48 AM
"All vacuum lines are connected, aka no loose vacuum hoses anywhere." AND "The stacked elbow is a few weeks out still and that is definitely leaking for sure..." are not congruent. "con·gru·ent kənˈɡro͞oənt,ˈkäNGɡro͞oənt/ adjective adjective: congruent 1.in agreement or harmony." Nah they are perfectly congruent since the second post is after doing some more checks, realizing it was leaking after disconnecting it and sticking my finger over the port in the plenum and having everything even out. Leak didn't have anything to do with loose hoses anyways (IMG:style_emoticons/default/biggrin.gif) They are routed correctly, in the exact same place they were stock. I tried different lengths of normal fuel line under there and I couldn't get good results, so I went with an upgraded material that has so far solved the issue. Clamps are all FI clamps not worm clamps. Gauge was hooked up on the driver side fuel rail after disconnecting the cold start valve. Don't have a pic cause it's pretty simple. Same setup basically as was on my Squareback's D-jet. |
Lo-Fi Version | Time is now: 11th June 2024 - 05:15 AM |
