Mega squirt vs micro squirt educate me |
mb911 |
Dec 10 2016, 05:31 PM
914 Guru Group: Members Posts: 6,902 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
So I am building a 2.4 6 with s pistons, solex cams and ported heads. I have webers and have considered a couple of paths. I have used megasquirt in the past on a 3.2 short stroke turbo engine using an adaptation of the bitz racing kit..
I am considering many things from machining the intakes to accept injectors and using the webers as throttle bodies to making a all sheet metal intake.. I would really like use a ecu that has a usb port etc. I am looking for feed back .. Utlimatly the system I used before was bullet proof.. Thoughts? |
ConeDodger |
Dec 10 2016, 06:19 PM
Apex killer! Group: Members Posts: 23,622 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
So I am building a 2.4 6 with s pistons, solex cams and ported heads. I have webers and have considered a couple of paths. I have used megasquirt in the past on a 3.2 short stroke turbo engine using an adaptation of the bitz racing kit.. I am considering many things from machining the intakes to accept injectors and using the webers as throttle bodies to making a all sheet metal intake.. I would really like use a ecu that has a usb port etc. I am looking for feed back .. Utlimatly the system I used before was bullet proof.. Thoughts? Jenvey TB's? Save the Webers... Attached image(s) |
Lo-Fi Version | Time is now: 16th June 2024 - 08:22 AM |
