So I am building a 2.4 6 with s pistons, solex cams and ported heads. I have webers and have considered a couple of paths. I have used megasquirt in the past on a 3.2 short stroke turbo engine using an adaptation of the bitz racing kit..
I am considering many things from machining the intakes to accept injectors and using the webers as throttle bodies to making a all sheet metal intake..
I would really like use a ecu that has a usb port etc. I am looking for feed back ..
Utlimatly the system I used before was bullet proof.. Thoughts?
