Mega squirt vs micro squirt educate me |
mb911 |
Dec 10 2016, 05:31 PM
914 Guru Group: Members Posts: 6,902 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
So I am building a 2.4 6 with s pistons, solex cams and ported heads. I have webers and have considered a couple of paths. I have used megasquirt in the past on a 3.2 short stroke turbo engine using an adaptation of the bitz racing kit..
I am considering many things from machining the intakes to accept injectors and using the webers as throttle bodies to making a all sheet metal intake.. I would really like use a ecu that has a usb port etc. I am looking for feed back .. Utlimatly the system I used before was bullet proof.. Thoughts? |
914forme |
Dec 12 2016, 09:34 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Yes have the SDS, actually several different EFI units. And have always wanted to install one. On my EG build I will be changing to MS3 Pro, just to much good stuff like E85 sensor not to go that direction. (IMG:style_emoticons/default/happy11.gif)
Andyrew |
Dec 12 2016, 10:39 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Yes have the SDS, actually several different EFI units. And have always wanted to install one. On my EG build I will be changing to MS3 Pro, just to much good stuff like E85 sensor not to go that direction. (IMG:style_emoticons/default/happy11.gif) That is an excellent reason to go pro (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 16th June 2024 - 07:39 AM |
