Replacing steering column wiper switch, should the brass tab be grounding to the steering column? |
seanpaulmc |
Dec 19 2016, 07:52 PM
Member Group: Members Posts: 304 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
The arm for the wiper switch coming out of the steering column in my '73 has been cut away. You can see that in the photos. Will this be hard to fix? Where can I source one?
Thank you! |
Valy |
Dec 21 2016, 06:00 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
You don't need to remove the 6 allen screws (actually don't even try).
Remove the horn button in the center and there is a big nut behind it that holds the wheel. Then there are 4 screws that hold the wipers and signaling switches. Please make sure you notice the small copper tab that comes loose with one of the screws. You will need it to ground the switches and many people loose it in the process. |
Lo-Fi Version | Time is now: 8th June 2024 - 05:03 AM |
