TM_Corey |
Member ![]() ![]() Group: Members Posts: 231 Joined: 28-March 16 From: Indianapolis Member No.: 19,809 Region Association: Upper MidWest ![]() |
The original sun visors in my 74 2.0 are in near perfect condition except for the crunchy foam that I can deal with, but it appears the plastic framework has shrunk a tad.
They barely fit in the brackets and I have a feeling once it is back on the road in the Spring that they will unhook easily on rough roads. Is there a trick in getting them to fit again? Some kind of extender maybe? |
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,954 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
Based on what I think you're describing you should adjust the shafts and pull them out of the visor a bit more. If you loosen the screws you should be able to pull them out a little farther so they fit better in the holders. Those shafts are two different pieces and you can move them independently of each other.
Edit: should also probably point out that those screws can be used to adjust the amount of force required to move the visor, so don't crank them down too hard. |
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,629 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
Based on what I think you're describing you should adjust the shafts and pull them out of the visor a bit more. If you loosen the screws you should be able to pull them out a little farther so they fit better in the holders. Those shafts are two different pieces and you can move them independently of each other. Edit: should also probably point out that those screws can be used to adjust the amount of force required to move the visor, so don't crank them down too hard. (IMG:style_emoticons/default/agree.gif) |
TM_Corey |
Based on what I think you're describing you should adjust the shafts and pull them out of the visor a bit more. If you loosen the screws you should be able to pull them out a little farther so they fit better in the holders. Those shafts are two different pieces and you can move them independently of each other. Edit: should also probably point out that those screws can be used to adjust the amount of force required to move the visor, so don't crank them down too hard. (IMG:style_emoticons/default/agree.gif) Sweet, I will try that. Thank you! |
Lo-Fi Version | Time is now: 17th July 2025 - 09:37 AM |
