> Larger chokes (venturies) on my Webers?
Eddie914
post Oct 19 2004, 07:35 PM
Unregistered
I have removed the Weber 40IDC 3A carbs for a rebuild.
They currently have 32mm venturies.
Will larger venturies give more top end power?
The engine is 2.7 from a '77 911. Internals (P/Cs, compression ratio, Cams) are unknown. Bursch Headers with megaphones (with removable baffles).
The car is 90% track. Weighs less than 2100lbs.
Thanks
Eddie
Root_Werks
post Oct 21 2004, 09:08 AM
Village Idiot
Hey Eddie,
Put those 40/36's on that guys 2.8 last night and holy (IMG:style_emoticons/default/ohmy.gif) !!! Big difference on his car. Althoug he has 37mm ports, mod E cams and 9.5/ratio so his engine was just eating up the fuel last night. We of course had to "Test" drive the new carbs. (IMG:style_emoticons/default/biggrin.gif) Anyway, the set we pulled off his car are 40/34's not 40/36's like I thought. Bummer, but if you want to try them out, I don't think he will care at all for a while. They are in pretty good shape and should be a bolt on and go sort of thing. Good enough to just fiddle around with. Up to you. (IMG:style_emoticons/default/boldblue.gif)
Eddie914   Larger chokes (venturies) on my Webers?   Oct 19 2004, 07:35 PM
TimT   Yes you will get more top end, but you will give...   Oct 19 2004, 07:44 PM
campbellcj   I could be wrong (it happens every few years :sha...   Oct 19 2004, 09:29 PM
fiid   Did you know if you spell carbs wrong you get crab...   Oct 19 2004, 10:06 PM
nebreitling   LMFAO...   Oct 19 2004, 10:23 PM
Eddie914   I pulled the carbs apart tonight. Current jetting...   Oct 20 2004, 01:43 AM
J P Stein   It's not a good idea to just change one aspect...   Oct 20 2004, 02:03 AM
Joe Ricard   Well Maybe I'm and idiot (I doubt it) But CIS ...   Oct 20 2004, 06:23 AM
Root_Werks   For something cammed like a 2.7S engine you will w...   Oct 20 2004, 08:50 AM
Thorshammer   Since the SCCA has stuck me with 34mm Venturis, I ...   Oct 20 2004, 10:09 AM
Eddie914   The power curve is fairly linear. The rev limiter ...   Oct 20 2004, 11:33 AM
Root_Werks   Probably, they are going on a cutomers 2.8 tonight...   Oct 20 2004, 11:39 AM
Eddie914   Dan, Oops! I meant to ask if the 40/36 Weber...   Oct 20 2004, 11:44 AM
Root_Werks   Hmm, I might have another set we could use though....   Oct 20 2004, 11:46 AM
Eddie914   I'll do the antipercolation modifications and ...   Oct 20 2004, 12:38 PM
J P Stein   ...   Oct 20 2004, 06:00 PM
Eddie914   JP, What are the specs on your 2.7? What are the...   Oct 21 2004, 08:50 AM
Root_Werks   Hey Eddie, Put those 40/36's on that guys 2.8...   Oct 21 2004, 09:08 AM
J P Stein   ...   Oct 21 2004, 12:52 PM
Eddie914   Dan, Thanks for the offer. I'd love to try ou...   Oct 22 2004, 12:01 AM
- Lo-Fi Version Time is now: 11th July 2025 - 04:04 PM
