Throttle Hand Lever Interference with Appearance Group Console, Does anyone have both of these options together? |
jkb944t |
Jan 3 2017, 08:17 PM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I installed the throttle hand lever last night and then tried to test fit the appearance group console tonight. I found that the throttle lever is too far forward to work as designed with the console.
Has anyone run into this situation before and found a solution? I am considering turning the throttle lever around 180 degrees but I am not sure yet if this would work correctly or not. Too tired tonight to figure anything out but was hopeful someone had dealt with this already. Jeff B |
Mikey914 |
Jan 4 2017, 06:51 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I'm thinking modifying the consul is the best option. I have a 75 with carbs so might as well prototype on mine.
Lo-Fi Version | Time is now: 9th June 2024 - 05:58 AM |
