Fuel Pump Questions, Was: FI Wiring Question |
ThinAir |
May 12 2003, 11:10 PM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
It looks like I've got a bad pump. Everything is plumbed to match Dave Darling's hose diagram and I've checked it against a known good 73. To be sure, I did some additional testing.
The connector that is closest to the electrical hookup is the one that has the T on it to connect to the return line in the tunnel and to the fuel pressure regulator. I'm testing by hooking the gauge directly to the center outlet of the pump. If I clamp between the T and the fuel pressure regulator, I get about 1 psi on the gauge. If I clamp between the T and the tube in the tunnel, I get about 10 psi. If I test with no lines clamped, I get about 5 psi. I bought this pump a few months back and have never used it until now. The Haynes manual says that the pre-72 and 72-74 pumps are "similar". I don't know for sure what year this one came out of. Does anyone know if there are any differences between pumps? Like, should the two "outside" hose connections be reversed? Does any of this information give anyone a clue about what is going on? |
Mike9142.0 |
May 13 2003, 12:29 AM
Member Group: Members Posts: 219 Joined: 29-January 03 From: Phoenix, AZ Member No.: 208 Region Association: Southwest Region |
Thanks Brad.
Lo-Fi Version | Time is now: 2nd June 2024 - 03:21 PM |
