> Rear Mounted Auxiliary Oil Cooler, An alternative to the front mounted unit
earossi
post Oct 31 2016, 08:34 PM
I can't locate the post; but someone was asking about mounting the front auxiliary cooler for a 6/ conversion project. I had responded about an alternative that involves mounting a cooler and cooling fan in the engine bay of a 914. I have attached several pictures of such an installation. This was not my car; however, my installation was essentially the same as depicted in the attached photos.
The cooler and fan carried a price tag of less than $400. To install the cooler, you have to fabricate some brackets as shown in the pictures. You'll need to route 12 volts to the cooler which incorporates a thermostatic temperature switch to actuate the booster cooling fan when oil temperatures reach a predetermined point. You'll also have to fabricate two short jumper hoses to take suction from the engine mounted oil cooler.
There are a number of these installations out there, including the one in my car. Several are running down in Dallas and work well.
Installing this rear mounted cooler deletes the need for hoses to be routed to the front of the car, and for body modifications needed to mount an oil cooler in the front trunk. The cooler is available from Savage, or from any number of suppliers.
sjhenry1075
post Jan 17 2017, 02:38 PM
At what point do you need to think about adding an extra cooler? At what displacement is the stock cooling system no longer effective? I know a lot of it depends on driving, but minus any sort of racing, is there a standard for when to add an extra cooler?
earossi   Rear Mounted Auxiliary Oil Cooler   Oct 31 2016, 08:34 PM
Mark Henry   I posted this set-up a while back done by Henry Sc...   Oct 31 2016, 09:30 PM
mb911   I posted this set-up done by Henry Schmidt of Sup...   Nov 2 2016, 10:55 AM
Perry Kiehl   I've done three coolers under the rear trunk, ...   Nov 1 2016, 06:06 AM
Mark Henry   I don't like the idea of pre-heating air go...   Nov 1 2016, 10:08 AM
Cairo94507   If I had not done the GT front cooler set-up for m...   Nov 1 2016, 07:30 AM
patssle   http://imgur.com/a/6u4ew   Nov 1 2016, 07:46 AM
rudedude   earossi, How well does your cooler in that positio...   Nov 1 2016, 07:51 AM
Elliot Cannon   Here's mine. Fans work great when you're ...   Nov 1 2016, 11:55 AM
porschetub   Here's mine. Fans work great when you're...   Nov 1 2016, 08:15 PM
ClayPerrine   Here are some pictures of the oil cooler on the cu...   Nov 1 2016, 12:05 PM
barefoot   In the Lapuwali classic forum: http://www.914worl...   Nov 1 2016, 03:31 PM
SirAndy   Just FYI, you can run a front cooler without cutti...   Nov 1 2016, 04:52 PM
JmuRiz   Just FYI, you can run a front cooler without cutt...   Nov 1 2016, 05:41 PM
Mark Henry   Just FYI, you can run a front cooler without cut...   Nov 1 2016, 06:07 PM
SirAndy   Just FYI, you can run a front cooler without cutti...   Nov 1 2016, 07:11 PM
FourBlades   I have a cooler with a fan mounted under my rear t...   Nov 1 2016, 05:13 PM
Cracker   No matter the engine...I have tried in vain to do ...   Nov 1 2016, 06:10 PM
Mark Henry   No matter the engine...I have tried in vain to do...   Nov 1 2016, 06:33 PM
Cracker   Mark - Although I hadn't quoted FourBlades com...   Nov 1 2016, 06:48 PM
Catorse   No matter the engine...I have tried in vain to do...   Nov 1 2016, 07:33 PM
JustinMeier   I have a 2.7 and the cooler was put in the trunk w...   Nov 2 2016, 12:40 AM
6freak   I have a 2.7 and the cooler was put in the trunk ...   Jan 17 2017, 04:07 PM
JustinMeier   I have a 2.7 and the cooler was put in the trunk...   Jan 18 2017, 09:24 AM
socal1200r   I don't know much about 914s, so I'm guess...   Nov 2 2016, 11:27 AM
Mark Henry   I don't know much about 914s, so I'm gues...   Nov 2 2016, 12:15 PM
SixerJ   I like the idea of a rear cooler on the grounds of...   Nov 2 2016, 05:10 PM
sjhenry1075   At what point do you need to think about adding an...   Jan 17 2017, 02:38 PM
BeatNavy   At what point do you need to think about adding a...   Jan 17 2017, 04:38 PM
Dave_Darling   At what point do you need to think about adding a...   Jan 17 2017, 10:25 PM
MoveQik   I've been running this set up on my 3.2 since ...   Jan 17 2017, 03:14 PM
JmuRiz   Good to know, I have the same cooler, going to moc...   Jan 17 2017, 03:20 PM
stugray   I installed mine in the front headlight buckets be...   Jan 17 2017, 05:23 PM
- Lo-Fi Version Time is now: 1st July 2025 - 02:40 PM
