> Prepping RD sheet metal., ...quick question...
mbseto
post Jan 25 2017, 01:51 PM
The panels from RD have some sort of primer coat on them, I don't think it is a weld-through type. Just wondering what the typical prep process is... Where I need to weld, I've been wheeling the coat off and applying weld-through primer. For the rest of it, it looks like everyone applies an anti-rust coat- are you removing the existing coat and using your own primer, then applying anti-rust, or just primering and anti-rust right over what's there?
Thanks...
amfab
post Jan 25 2017, 02:38 PM
It is not a weld-through coating, they are using Galvanneal steel.
https://www.youtube.com/watch?v=8mKmYt_uwIA
They do not specify how to weld it in that video.
It is galvanized but it is heated afterwards so the top creates a bit of an alloy so the zinc will not flake.
I assume: grind the spots, then weld using a weld-through primer. That is what they seem to do in their videos. I know Lincoln makes some specialty wire for this application that allows direct welding of it but I haven't researched it that much. It may be for some specific industrial welders. If you find anything else out let me know as I have a pile of RD parts I just had delivered.
edit: Yeah what Rob said,
-Andrew
- Lo-Fi Version Time is now: 4th July 2025 - 11:04 PM
