| driver66 |
May 13 2003, 04:56 AM
Member ![]() ![]() Group: Members Posts: 71 Joined: 11-May 03 From: sullivan,illinois Member No.: 678 |
2YEARS INTO 914'S ,BUT ALL MY LIFE IN MECHANICS. IVE BEEN GETTING BAD FEEDBACK FROM MY FRONT END TO MY STEERING WHEEL. NOW KEEP IN MIND I NEED TIRES . SO, IM LOOKING FOR BAD TIERODS OR ANYTHING THAT WOULD EXPLAIN THIS PROBLEM,YESTERDAY I LIFTED THE DRIVERS FRONT TIRE LEAVING THE OTHER DOWN AND BEGAN ROCKING THE WHEEL FROM THE 9OCLOCK AND 3 O-CLOCK POSITIONS AND LEARNED THAT BOTH WERE MOVEING WITH LITTLE OR NO PLAY,THE PLAY WAS IN THE FEED BACK TO THE LOCKED STEARING WHEEL.,,,,,,SO MY QUESTION IS ,IS THIS NORMAL TO 914 RACKS OR IS MINE WORE OUT??HOW MUCH PLAY SHOULD YOU HAVE THERE? AND THERE PROBLY IS NO ADJUSTMENT IS THERE?????
| JWest |
May 13 2003, 07:24 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,664 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None
There should be almost no play in a good 914 rack. They are not really prone to wear either. You could have a damaged rack, worn or loose u-joints, loose rack mount bolts, bad inner tie-rod bushings (they are rubber), bad outer tie-rods, or loose wheel bearings.
I think you will find the problem if you go through the system one piece at a time, as it is pretty simple and direct. |
driver66 WHAT THE ???? May 13 2003, 04:56 AM
Racer Chris There are 2 u-joints in the steering linkage which... May 13 2003, 05:18 AM
Lawrence914-6 Hi Driver66... welcome to the BBS!!
You m... May 13 2003, 07:20 AM
Jeffs9146 Mine did that when I first bought it and it turned... May 13 2003, 07:48 AM
Gint Hey driver66, welcome to the board.
I have to ask... May 13 2003, 08:22 AM
driver66 thanks for the input , im gonna go after it w/diff... May 15 2003, 05:20 AM
Bleyseng There are some 140's for sale in the Classifie... May 15 2003, 08:59 AM
driver66 ok,my bushings are out on the tie rods were they h... May 18 2003, 09:07 AM
rhodyguy the ttr's eliminate those stupid rubber bushin... May 18 2003, 09:14 AM
Gint I wouldn't even bother getting bushings for th... May 18 2003, 07:29 PM
driver66 thanks again.............getting tires tuesday. ... May 19 2003, 04:31 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 01:20 AM |
