splitting gauges |
splitting gauges |
JFG |
Feb 8 2017, 07:25 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I've been looking at taking the rear covers off to aid cleaning, removing stuck bulbs and renovating.
I'm a tad hesitant though as i don't know what is loose inside. For example will springs fling out into the never to be found again place? Can the outer rings be removed from the gauges? I have the multi function gauge (temp fuel 4 lights) Speedo and rev counter |
porschetub |
Feb 8 2017, 12:55 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Face done on a flat surface with a cloth underneath,I used a combination of a blunt ended kitchen knife and various flat screwdrivers.
Don't forget to keep moving around the edge so you evenly pry open the ring,only open it a small amount @ a time,if you swear a lot don't worry its part of the job (IMG:style_emoticons/default/headbang.gif) ,I have done 3 now,first one took the most time. |
Lo-Fi Version | Time is now: 10th June 2024 - 01:49 AM |
