Front hood pins for steel hood DYI |
mlindner |
Feb 14 2017, 09:34 AM
Senior Member Group: Members Posts: 1,530 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Started this project a few weeks ago. Needed (wanted) front GT style hood pins. Put in the base plate, while checking angle of pin, I noticed the hood plate would have to have a elongated hole to accommodate the pin as the hood comes down. Sooo, with some careful measuring, the angle of the hood pin needed to be at 19 deg angle (or at 81 deg. verses 90. deg to the support plate) The answer to this was nylon collars top and bottom with the 19 deg. bevel. Worked out great, NO elongating. And best with the beveled collars they can be rotated left/right for perfect alinement. Best, Mark
tygaboy |
Feb 14 2017, 10:32 AM
914 Guru Group: Members Posts: 5,314 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
That right there? That is what I call "tidy". (IMG:style_emoticons/default/wub.gif)
VERY nice work. It's that sort of detail that makes a build stand out. You should be proud. |
Lo-Fi Version | Time is now: 10th June 2024 - 11:28 AM |
