Fuel gauge sender |
Fuel gauge sender |
HalfMoon |
Feb 17 2017, 11:08 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
My fuel sender is not registering anything below 1/4 tank.
As you might expect, in an ohm test I'm not getting w=0, G=70-100 (empty) or w=infinite, G=1-10 (full). The thing that's odd....the wire is intact it's entire length, all contacts and the wire (and ground wire) were cleaned until cotton swabs were no longer returning dirt, points of contact the floater to the wires is good yet a continuity test towards the bottom of the sender wire/s shows fading continuity until none. Is it possible for the copper wire to simply lose it's capacity to conduct over 44 years (as I believe the sender to be the original)? Is it possible the internals of the flaoter are corrupt (hmmm...must do a continuity test those contact point tomorrow). Yes, I'm aware I can go out a buy a new one. I'd rather learn how to fix a broken one. Why? Because I want to. Soooo, anyone wanna chime in their experience? Thanx |
Tbrown4x4 |
Feb 18 2017, 07:45 AM
Senior Member Group: Members Posts: 705 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Does the low fuel light ever come on? Could the float be sticking?
Mine would hang up on 3/4 tank until I hit a bump and it would go up or down from there and be fine after that. When I had it apart, I found a lot of corrosion on the main rod where the float rides. Cleaned and polished the rod, and it's fine now. |
HalfMoon |
Feb 18 2017, 10:28 AM
Does the low fuel light ever come on? Could the float be sticking? Mine would hang up on 3/4 tank until I hit a bump and it would go up or down from there and be fine after that. When I had it apart, I found a lot of corrosion on the main rod where the float rides. Cleaned and polished the rod, and it's fine now. I have it out and out of the tube. It's clean as a whistle and definitely not sticking |
Lo-Fi Version | Time is now: 11th June 2024 - 06:37 PM |
