> safety, reliability and originality, the learning never stops
iankarr
post Feb 20 2017, 09:27 PM
Hi Guys,
The more time I spend with my "new" 74, the more original I realize it is. It runs amazingly well, but...
The fuel pump is from day 1 and still in the rear location. Plastic fuel lines. Original vacuum hoses, spark plug wires, points, etc. The engine compartment is a bit dusty, but it's a time machine.
I know I should replace the fuel lines to keep from becoming a fireball, but should I also relocate the pump to the front "while I'm at it?". Which of Tangerine's SS kits is best? And is it wise to depend on a 43 year old pump...or replace / rebuild it?
I have nothing against points, but I've always run pertronix in my classics, so I'll probably put an ignitor II in the dizzy and keep the points as a backup.
I know I've made a flurry of posts in the past few days, but this car is so surprisingly different from my 73 / 2056 carbed car. Lots to learn.
Ultimately, I realize that part of owning this car will be deciding how much to keep original. For example, there's no evidence of rust on the floor pans, but do I pull up the factory tar and remove that piece of "history"?
This will be an interesting process!
Here's a link to the engine and undercarriage pics. Thanks, as always for the help and opinions.
https://pix.sfly.com/cEddbQ
Ian
Mark Henry
post Feb 20 2017, 10:21 PM
that's what I do!
The plastic lines are actually nylon, if they are in good shape you don't really have to replace them. it's the old hoses and PO's using regular worm gear hose clamps that are the fire hazard.
Also if the through the body grommets are in bad shape they could cut the lines, but reality is if the grommets are missing the body metal will saw through the SS lines almost as fast.
Many times I find the pumps fail from sitting too long. If it's in good order and you drive the car every couple weeks during the season they usually are fine.
- Lo-Fi Version Time is now: 2nd April 2026 - 03:14 PM
