> safety, reliability and originality, the learning never stops
iankarr
post Feb 20 2017, 09:27 PM
Hi Guys,
The more time I spend with my "new" 74, the more original I realize it is. It runs amazingly well, but...
The fuel pump is from day 1 and still in the rear location. Plastic fuel lines. Original vacuum hoses, spark plug wires, points, etc. The engine compartment is a bit dusty, but it's a time machine.
I know I should replace the fuel lines to keep from becoming a fireball, but should I also relocate the pump to the front "while I'm at it?". Which of Tangerine's SS kits is best? And is it wise to depend on a 43 year old pump...or replace / rebuild it?
I have nothing against points, but I've always run pertronix in my classics, so I'll probably put an ignitor II in the dizzy and keep the points as a backup.
I know I've made a flurry of posts in the past few days, but this car is so surprisingly different from my 73 / 2056 carbed car. Lots to learn.
Ultimately, I realize that part of owning this car will be deciding how much to keep original. For example, there's no evidence of rust on the floor pans, but do I pull up the factory tar and remove that piece of "history"?
This will be an interesting process!
Here's a link to the engine and undercarriage pics. Thanks, as always for the help and opinions.
https://pix.sfly.com/cEddbQ
Ian
rgalla9146
post Feb 21 2017, 08:26 AM
I am surprised and happy to see reasonable responses to the fuel line issue.
The SS fuel lines are a great idea and a perfect replacement and repair.
But...If your tunnel plumbing is un-disturbed and the exposed front and rear
sections are are pliable it is not necessary to replace them.
Replacement with the proper hose and proper clamps is often all that is necessary
- Lo-Fi Version Time is now: 2nd April 2026 - 03:14 PM
