Garage Clean Out, Mostly type 4 |
eric914 |
Feb 26 2017, 03:15 PM
Member Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest |
[/s]European Motor works 054-106H cam new $150 / sell $105 European Motor Works cam gear new $40 / sell $28 More to follow Attached thumbnail(s) |
eric914 |
Feb 26 2017, 04:30 PM
26mm gears.
From their website - Maxi Pump 1 - The Maxi Pump 1 is the perfect oil pump for street, off-road and competition. The die cast blue-printed housing features a "pressure chamber" to help provide a constant flow of oil. The added volume and anti-cavitation features of the Maxi 1 make it the top choice for use with external oil cooler and filter systems. The Maxi 1 slips right in to replace your stock oil pump. Fuel pump is low pressure for carbs. |
KevinW |
Feb 28 2017, 06:00 AM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
26mm gears. From their website - Maxi Pump 1 - The Maxi Pump 1 is the perfect oil pump for street, off-road and competition. The die cast blue-printed housing features a "pressure chamber" to help provide a constant flow of oil. The added volume and anti-cavitation features of the Maxi 1 make it the top choice for use with external oil cooler and filter systems. The Maxi 1 slips right in to replace your stock oil pump. Fuel pump is low pressure for carbs. PM sent for oil pump |
Lo-Fi Version | Time is now: 7th June 2024 - 04:11 AM |
