> Alternator Woes...well maybe
57lincolnman
post Feb 28 2017, 12:34 AM
I have a '75 1.8L that seems to have a charging problem. The battery was recently replaced and tests at 12.2v. The alternator was replaced about 6 years ago and when tested checks out at spec. So does the voltage regulator. The headlights were just replaced with LEDs which are great and draw less current than the old 100w bulbs and really light the way. The alternator drive belt does not squeal but I do smell burning rubber occasionally. Without any load on the electrical system the volt gauge reads 13v consistently at speed and maybe drops to 12v at idle.
Here's the problem... when driving with the headlights on the volt gauge barely registers 12v and is on the discharging side. When stopped at a stop light at idle with the headlights on, the volts drops to 11v. If I use the turn signal while stopped and have the lights on, it drops to nearly 10v. The battery is seriously discharging here.
This has been a persistent problem for some time, but has become exacerbated since I recently moved to SoCal where stop and go (mostly stop) traffic is a fact of life. Has anyone experienced this problem or have a suggestion?
phatnine11
post Feb 28 2017, 11:53 AM
57Lincolnman,
I have the same problem on my '75, sometimes my gauge registers that the alt is charging, sometimes it reads that I am discharging. I spent 10 bucks on a voltmeter that plugs into the cig lighter socket (cellphone charging port for you young ones!). The alt now reads that it is always above 12.5 volts, so I don't trust my 42 year old VDO meter. If you still are unsure about your charging system, put a voltmeter across the battery cables and and compare your VDO meter to your tester.
Just my $0.02.
Phatnine11
- Lo-Fi Version Time is now: 3rd July 2025 - 08:58 PM
