> Engine won't crank - earth or more serious?
euro914er
post Feb 28 2017, 07:28 AM
Region Association: England
Hi everyone,
I'm a new UK owner - circa 6 months - of a 1.8L, 1974 in chrome yellow. The car is ex west coast, then was imported into the UAE by its PO around 4 years ago. There it was stripped down, repainted and reupholstered. The engine was put back in, but never recommissioned. The PO then came back to the UK about 2 years but never got around to connecting everything back up - all the vac hoses were missing, fuel lines gone and lots of wires go nowhere. Well I've sorted all of this and a few weeks back I attempted to turn her over. I was met with a "click" and after a quick google, internet wisdom pointed towards the solenoid. This was replaced and now the click has turned into a thunk. Jacking the wheel up and putting it into fifth, I can just about get the wheel to turn 180 degrees before I reach a hard stop. Plugs are out and diesel has been poured into to each cylinder. BTW - some leaks out of one cylinder - should it be doing that?
I'm now at the limit of my knowledge - some posts suggest its an earth strap problem - others suggest something more serious such as a stuck valve. The drivers side valve cover is over and all looks normal (according to a colleague). The passenger side will be more tricky as its deeply buried.
So what does the collective feel should be my next move? I've resisted pulling out the engine but I have a feeling I'm head that way. As you can see, she's mint apart from a sick engine
euro914er
post Feb 28 2017, 02:31 PM
Thanks ottox914.
Plugs are pulled and the drivers side valve cover is off but to be honest I'm not sure what 'way off' looks like. As you'll know passenger side is more deeply buried. I'll add a photo in a following post.
euro914er   Engine won't crank - earth or more serious?   Feb 28 2017, 07:28 AM
bdstone914   Need a little more info to help you. Does anythin...   Feb 28 2017, 08:21 AM
euro914er   Thanks for the welcome. Battery is brand new. Wit...   Feb 28 2017, 01:54 PM
ottox914   Pulling the plugs should make it easier to turn ov...   Feb 28 2017, 02:03 PM
euro914er   Thanks ottox914. Plugs are pulled and the driver...   Feb 28 2017, 02:31 PM
timothy_nd28   I have a bad feeling that something dropped down y...   Feb 28 2017, 02:47 PM
euro914er   I'm scared to asked - what was the outcome?   Feb 28 2017, 03:14 PM
Perry Kiehl   With the spark plugs out you should be able to tur...   Feb 28 2017, 04:05 PM
euro914er   Thanks for that advice..I'll give the borescop...   Feb 28 2017, 04:58 PM
euro914er   Hi all, managed to get rocker covers off at the we...   Mar 6 2017, 07:26 AM
McMark   Rotate the engine while watching the rockers. You...   Mar 6 2017, 07:35 AM
Bartlett 914   I had a similar to a motor that had been sitting a...   Mar 6 2017, 08:04 AM
Bob L.   Have you checked the impeller fan for obstruction?   Mar 6 2017, 09:38 AM
euro914er   Fan 'feels' clear but I've just ordere...   Mar 7 2017, 06:47 AM
euro914er   Hi all, just to update you. Last weekend I dropp...   Mar 21 2017, 07:30 AM
euro914er   More carnage   Mar 21 2017, 07:31 AM
euro914er   Suring surgery   Mar 21 2017, 07:32 AM
Vacca Rabite   Well, better to know and get it fixed. The piston ...   Mar 21 2017, 07:46 AM
- Lo-Fi Version Time is now: 15th July 2025 - 04:11 AM
