| 80cap |
Mar 2 2017, 01:28 PM
Member ![]() ![]() Group: Members Posts: 322 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
What is the best psi for a carb setup? I already have a low pressure pump but I read that it still might be to high.
Brian |
| Elliot Cannon |
Mar 3 2017, 12:17 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
I have been using this for my 44idf Webers for about 15 years without a regulator. http://www.cbperformance.com/product-p/3193.htm
80cap fuel pressure regulator Mar 2 2017, 01:28 PM
Harpo 3.5 psi for carbs Mar 2 2017, 03:58 PM
Junebug Depends on Carbs, I use a Holly at 2 psi for 10 mm... Mar 2 2017, 08:07 PM
porschetub
Depends on Carbs, I use a Holly at 2 psi for 10 m... Mar 3 2017, 02:38 PM
Junebug
[quote name='Junebug' post='2460045' date='Mar 3 ... Dec 14 2019, 10:41 AM
Junebug Oh here's that car "Tang" on the rot... Dec 14 2019, 11:07 AM
80cap I have dual dell's and the cb performance fuel... Mar 3 2017, 06:15 AM
stugray One thing to keep in mind: If you are using pump g... Mar 3 2017, 08:03 AM
80cap I plan on 91 octane with no ethanol.
Just down th... Mar 3 2017, 11:31 AM
stugray
Just down t... Mar 3 2017, 11:55 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:09 PM |
