Money and motor options, What is a realistic budget and parts list |
thelogo |
Mar 13 2017, 09:50 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
1st off the engine im going for in no way needs to
Be optimised for performance (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/stirthepot.gif) What is the best combo for just cool reliable running In socal heat . Im trying to stay clear of d jet (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bootyshake.gif) So carbs or i like cb performance f.i kit but know little actually about it . What Crank Pistons Rods Cam Cyclinder s Fuel delivery Etc should i be putting together and what kinda budget windfall Should i be prepared for . I know its a sickness but cant be that expensive? I will use a machine shop to build the motor That have extensive experience with type 4 So i know thats gonna cost me major $ (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/smoke.gif) Talk to me about proven engine combinatios (IMG:style_emoticons/default/beer3.gif) |
Dave_Darling |
Mar 13 2017, 10:29 PM
A sock 1.7 should hold up just fine under darned near any circumstances you throw at it. If you want to avoid D-jet, stick some Dells on it. Maybe drop the compression to the lower 73 CA-only spec (about 7.6:1) so you don't have to run premium.
You said it wasn't about performance.... --DD |
thelogo |
Mar 13 2017, 10:47 PM
A sock 1.7 should hold up just fine under darned near any circumstances you throw at it. If you want to avoid D-jet, stick some Dells on it. Maybe drop the compression to the lower 73 CA-only spec (about 7.6:1) so you don't have to run premium. You said it wasn't about performance.... --DD Thats pretty much the setup im runnin now 1.7 d,jet not running correctly, may just be f.i related But Do i rebuild a separate 1.7 and swap in Wait till my 1.7 breaks down then rebuild it It it even worth it building a fresh 1.7 or does that cost the same as a 2056 ? |
mgphoto |
Mar 14 2017, 09:39 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
A sock 1.7 should hold up just fine under darned near any circumstances you throw at it. If you want to avoid D-jet, stick some Dells on it. Maybe drop the compression to the lower 73 CA-only spec (about 7.6:1) so you don't have to run premium. You said it wasn't about performance.... --DD Thats pretty much the setup im runnin now 1.7 d,jet not running correctly, may just be f.i related But Do i rebuild a separate 1.7 and swap in Wait till my 1.7 breaks down then rebuild it It it even worth it building a fresh 1.7 or does that cost the same as a 2056 ? sort out the d-jet your car should be worth more with FI than a single carb, which is the cheapest way to go. |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:04 PM |
