| thelogo |
Mar 13 2017, 09:50 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
1st off the engine im going for in no way needs to
Be optimised for performance (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/stirthepot.gif) What is the best combo for just cool reliable running In socal heat . Im trying to stay clear of d jet (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bootyshake.gif) So carbs or i like cb performance f.i kit but know little actually about it . What Crank Pistons Rods Cam Cyclinder s Fuel delivery Etc should i be putting together and what kinda budget windfall Should i be prepared for . I know its a sickness but cant be that expensive? I will use a machine shop to build the motor That have extensive experience with type 4 So i know thats gonna cost me major $ (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/smoke.gif) Talk to me about proven engine combinatios (IMG:style_emoticons/default/beer3.gif) |
| Dave_Darling |
Mar 13 2017, 10:29 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
A sock 1.7 should hold up just fine under darned near any circumstances you throw at it. If you want to avoid D-jet, stick some Dells on it. Maybe drop the compression to the lower 73 CA-only spec (about 7.6:1) so you don't have to run premium.
You said it wasn't about performance.... --DD |
| thelogo |
Mar 13 2017, 10:47 PM
A sock 1.7 should hold up just fine under darned near any circumstances you throw at it. If you want to avoid D-jet, stick some Dells on it. Maybe drop the compression to the lower 73 CA-only spec (about 7.6:1) so you don't have to run premium. You said it wasn't about performance.... --DD Thats pretty much the setup im runnin now 1.7 d,jet not running correctly, may just be f.i related But Do i rebuild a separate 1.7 and swap in Wait till my 1.7 breaks down then rebuild it It it even worth it building a fresh 1.7 or does that cost the same as a 2056 ? |
| Dave_Darling |
Mar 14 2017, 10:58 AM
Do i rebuild a separate 1.7 and swap in Wait till my 1.7 breaks down then rebuild it It it even worth it building a fresh 1.7 or does that cost the same as a 2056 ? I'd say wait until yours is on the way out. Or get a spare (core 1.7s should be cheap!) and build it as time and budget allow. A 1.7 should be more reliable than a 2.0 or a 2056. They tend to be less stressed, have more robust rod journals, have heads that are less prone to cracking, and have less demanded of them. --DD |
thelogo Money and motor options Mar 13 2017, 09:50 PM
thelogo Im looking for air cooled type 4
And basically... Mar 13 2017, 09:54 PM
Mueller I think McMark does the 2056 for about $5k , ... Mar 13 2017, 10:25 PM
thelogo
I think McMark does the 2056 for about $5k ,... Mar 13 2017, 10:54 PM
mgphoto
A sock 1.7 should hold up just fine under darned... Mar 14 2017, 09:39 AM
Chris914n6 Depends on what you are starting with.
66mm or 71... Mar 13 2017, 10:56 PM
Larmo63 Look for a complete 2.0 core, tear it down to a lo... Mar 13 2017, 10:57 PM
struckn Most people won't get what I'm saying but ... Mar 14 2017, 08:45 AM
mepstein Another option is a WTB request. Every year, many ... Mar 14 2017, 09:02 AM
Tom_T Since you're in SoCal ....
I'm not sure ... Mar 14 2017, 10:01 AM
thelogo :toke: :worship:
Sound advice d.d
Im happy ... Mar 14 2017, 04:41 PM
Mueller
:toke: :worship:
Sound advice d.d
Im happy... Mar 14 2017, 04:59 PM
thelogo
[quote name='thelogo' post='2464191' date='Mar 14... Mar 14 2017, 06:40 PM
thelogo
:toke: :worship:
Sound advice d.d
Im happ... Mar 14 2017, 06:42 PM
Mike D.
How do you fuck up a single carb :WTF:
You d... Mar 14 2017, 07:03 PM
thelogo
You ... Mar 14 2017, 10:00 PM
struckn
[quote name='Mike D.' post='2464240... Mar 16 2017, 01:27 PM
Mueller
[quote name='Mike D.' post='2464240... Mar 16 2017, 03:50 PM
914sgofast2 The answer to building a good engine with the Djet... Mar 16 2017, 05:03 PM
thelogo
The answer to building a good engine with the Dje... Mar 16 2017, 09:24 PM
struckn Alright I have to respond to the question above. H... Mar 16 2017, 05:11 PM
Mueller
[quote name='thelogo' post='2464191... Mar 14 2017, 08:09 PM
JamesM
:toke: :worship:
Sound advice d.d
Im happy... Mar 18 2017, 12:25 PM
thelogo Do or dont get me wrong djet is great
If they ... Mar 14 2017, 09:50 PM
Dave_Darling
Carbs are universally understood by mechanics al... Mar 14 2017, 10:23 PM
Mueller $3000 for the CB Performance EFI, and that do... Mar 14 2017, 10:31 PM
thelogo
$3000 for the CB Performance EFI, and that d... Mar 14 2017, 11:20 PM
Mueller
$3000 for the CB Performance EFI, and that ... Mar 14 2017, 11:44 PM
AZBanks How does the D-jet and other 914 FI systems pick u... Mar 14 2017, 11:50 PM
falcor75
How does the D-jet and other 914 FI systems pick ... Mar 15 2017, 12:28 AM
BeatNavy
How does the D-jet and other 914 FI systems pick ... Mar 15 2017, 03:52 AM
barefoot
How does the D-jet and other 914 FI systems pick ... Mar 15 2017, 05:35 AM
Mark Henry Cheap (ish) FI I'd go with a fresh 914 2.0 205... Mar 15 2017, 06:25 AM
Dave_Darling Oh, look! A spammer has joined us!
--DD Mar 15 2017, 09:56 AM
AZBanks The reason I asked is because I have a business pa... Mar 15 2017, 10:05 AM
Mark Henry
The reason I asked is because I have a business p... Mar 15 2017, 12:16 PM
Mueller
The reason I asked is because I have a business p... Mar 15 2017, 12:25 PM
914forme A few years ago I would have said sell it, spend t... Mar 15 2017, 02:50 PM
thelogo
A few years ago I would have said sell it, spend ... Mar 15 2017, 03:27 PM
Mueller
A few years ago I would have said sell it, spend... Mar 15 2017, 09:00 PM
thelogo So other then L-jet
You could say there is no ... Mar 16 2017, 12:11 AM
914forme Okay well if you insist.
Take a 1.7 or 1.8L, I wo... Mar 16 2017, 02:07 PM
thelogo
You can spend some seri... Mar 16 2017, 04:27 PM
Mueller True bumper sticker I just saw;
"I'd rat... Mar 16 2017, 06:00 PM
struckn Forgot to mention My 2V Weber has an Electric Chok... Mar 16 2017, 07:27 PM
mepstein If you find a more reliable, affordable, bolt on s... Mar 17 2017, 06:31 AM
thelogo
If you find a more reliable, affordable, bolt on ... Mar 17 2017, 03:45 PM
Mueller
If you find a more reliable, affordable, bolt on... Mar 17 2017, 05:58 PM
thelogo
[quote name='thelogo' post='2465093' date='Mar 17... Mar 17 2017, 08:21 PM
Mueller I'm not going to lie, if I stumbled upon a pai... Mar 17 2017, 09:14 PM
thelogo
I'm not going to lie, if I stumbled upon a pa... Mar 17 2017, 10:15 PM
rdauenhauer :agree: Mar 17 2017, 07:05 AM
thelogo :beer3:
Purr
Meow
:toke: :wavebye: Mar 17 2017, 08:25 PM
AZBanks My next engine upgrade.
http://www.oreillyauto.co... Mar 17 2017, 10:34 PM
Robnxious
http://www.oreillyauto.c... Mar 18 2017, 01:45 PM
rush Does anyone know of a available L jet system 4 sal... Mar 18 2017, 11:17 AM
Mark Henry
Does anyone know of a available L jet system 4 sa... Mar 18 2017, 12:48 PM
914forme Carbs,
Best drivability are Dellortos 36mm for yo... Mar 18 2017, 12:26 PM
thelogo
Carbs,
Best drivability are Dellortos 36mm for y... Mar 19 2017, 12:41 AM
mgphoto
[quote name='914forme' post='2465325' date='Mar 1... Mar 19 2017, 08:24 AM
914forme Class 5 is a different animal and you are correct,... Mar 19 2017, 09:08 AM
Dave_Darling If you do go with a single-carb setup, consider he... Mar 19 2017, 01:51 PM
porsche913b_sp :type: Mar 19 2017, 05:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:32 AM |
