oil leak from flywheel bolts, do I need thread sealant here? |
davesprinkle |
Mar 15 2017, 01:30 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
My type 4 engine is leaking oil via the threads of the flywheel bolts. How does this leak-path get sealed?
Mark Henry |
Mar 15 2017, 03:13 PM
The RMS is under direct pressure from the #1 main bearing, the slightest scratch in the flywheel or crank mating surfaces will act like an oil galley.
One of the reasons not to use too much sealant on case halves is so you won't clog the RMS/rear main bearing oil drain notch. Clog that relief notch and the best seal in the world won't stop the oil coming out of the RMS. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:50 PM |
