| thelogo |
Mar 13 2017, 09:50 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
1st off the engine im going for in no way needs to
Be optimised for performance (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/stirthepot.gif) What is the best combo for just cool reliable running In socal heat . Im trying to stay clear of d jet (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bootyshake.gif) So carbs or i like cb performance f.i kit but know little actually about it . What Crank Pistons Rods Cam Cyclinder s Fuel delivery Etc should i be putting together and what kinda budget windfall Should i be prepared for . I know its a sickness but cant be that expensive? I will use a machine shop to build the motor That have extensive experience with type 4 So i know thats gonna cost me major $ (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/smoke.gif) Talk to me about proven engine combinatios (IMG:style_emoticons/default/beer3.gif) |
| thelogo |
Mar 14 2017, 04:41 PM
(IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/pray.gif)
Sound advice d.d Im happy with a 1.7 Not happy with djet . |
| Mueller |
Mar 14 2017, 04:59 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
(IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/pray.gif) Sound advice d.d Im happy with a 1.7 Not happy with djet . Could be operator error (IMG:style_emoticons/default/smile.gif) Any fuel system be it a single carb or even a $5,000 Motec system can give you fits if not in tip top shape and if you don't know how to work on it, you could spend $10K on a new motor with modern EFI or dual carbs and be miserable if not tuned correctly or you miss a simple vacuum line. I'd go thru all the basic troubleshooting of the FI and ignition 1st as well as a full tune up. |
| thelogo |
Mar 14 2017, 06:42 PM
[quote name='Mueller' date='Mar 14 2017, 03:59 PM' post='2464197']
[quote name='thelogo' post='2464191' date='Mar 14 2017, 03:41 PM'] (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/pray.gif) Sound advice d.d Im happy with a 1.7 Not happy with djet . [/quote] Could be operator error (IMG:style_emoticons/default/smile.gif) Any fuel system be it a single carb How do you fuck up a single carb (IMG:style_emoticons/default/WTF.gif) |
| Mike D. |
Mar 14 2017, 07:03 PM
OK, It runs now, and pretty good too! ![]() ![]() ![]() Group: Members Posts: 1,457 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None
You don't, it fucks you up. They are POS. And lose the mechanic that won't work on your car. Take it to Leamon in Tajunga. PM him, he's HeelToe914 |
| thelogo |
Mar 14 2017, 10:00 PM
You don't, it fucks you up. They are POS. And lose the mechanic that won't work on your car. Take it to Leamon in Tajunga. PM him, he's HeelToe914 Leamon is the coolest guy ever And yeh im sure he could help And the guy always seem to find the great cars too And my mechanic does a great job on the car But he told me . Way back when i got the car That the car was running well and he didnt really Touch the injection and every thing seems fine He recommended that as long as its all good to Run the djet And if it becomes a issue install webers |
| struckn |
Mar 16 2017, 01:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
[quote name='thelogo' date='Mar 14 2017, 08:00 PM' post='2464289']
[quote name='Mike D.' post='2464240' date='Mar 14 2017, 06:03 PM'] [quote name='thelogo' post='2464233' date='Mar 14 2017, 05:42 PM'] How do you fuck up a single carb (IMG:style_emoticons/default/WTF.gif) [/quote] You don't, it fucks you up. They are POS. And lose the mechanic that won't work on your car. Alright I have to respond to the question above. Here again is my Video of my Single Weber 1.8 with the correct Cam and attention to the carb floats adjustments done by Tony at Translog GT to make it run right. https://youtu.be/H4t0M2wrhu8 Doug |
thelogo Money and motor options Mar 13 2017, 09:50 PM
thelogo Im looking for air cooled type 4
And basically... Mar 13 2017, 09:54 PM
Mueller I think McMark does the 2056 for about $5k , ... Mar 13 2017, 10:25 PM
thelogo
I think McMark does the 2056 for about $5k ,... Mar 13 2017, 10:54 PM
Dave_Darling A sock 1.7 should hold up just fine under darned n... Mar 13 2017, 10:29 PM
thelogo
A sock 1.7 should hold up just fine under darned ... Mar 13 2017, 10:47 PM
mgphoto
A sock 1.7 should hold up just fine under darned... Mar 14 2017, 09:39 AM
Dave_Darling
Do i rebuild a separate 1.7 and swap in
Wait ... Mar 14 2017, 10:58 AM
Chris914n6 Depends on what you are starting with.
66mm or 71... Mar 13 2017, 10:56 PM
Larmo63 Look for a complete 2.0 core, tear it down to a lo... Mar 13 2017, 10:57 PM
struckn Most people won't get what I'm saying but ... Mar 14 2017, 08:45 AM
mepstein Another option is a WTB request. Every year, many ... Mar 14 2017, 09:02 AM
Tom_T Since you're in SoCal ....
I'm not sure ... Mar 14 2017, 10:01 AM
thelogo
[quote name='thelogo' post='2464191' date='Mar 14... Mar 14 2017, 06:40 PM
Mueller
[quote name='Mike D.' post='2464240... Mar 16 2017, 03:50 PM
914sgofast2 The answer to building a good engine with the Djet... Mar 16 2017, 05:03 PM
thelogo
The answer to building a good engine with the Dje... Mar 16 2017, 09:24 PM
struckn Alright I have to respond to the question above. H... Mar 16 2017, 05:11 PM
Mueller
[quote name='thelogo' post='2464191... Mar 14 2017, 08:09 PM
JamesM
:toke: :worship:
Sound advice d.d
Im happy... Mar 18 2017, 12:25 PM
thelogo Do or dont get me wrong djet is great
If they ... Mar 14 2017, 09:50 PM
Dave_Darling
Carbs are universally understood by mechanics al... Mar 14 2017, 10:23 PM
Mueller $3000 for the CB Performance EFI, and that do... Mar 14 2017, 10:31 PM
thelogo
$3000 for the CB Performance EFI, and that d... Mar 14 2017, 11:20 PM
Mueller
$3000 for the CB Performance EFI, and that ... Mar 14 2017, 11:44 PM
AZBanks How does the D-jet and other 914 FI systems pick u... Mar 14 2017, 11:50 PM
falcor75
How does the D-jet and other 914 FI systems pick ... Mar 15 2017, 12:28 AM
BeatNavy
How does the D-jet and other 914 FI systems pick ... Mar 15 2017, 03:52 AM
barefoot
How does the D-jet and other 914 FI systems pick ... Mar 15 2017, 05:35 AM
Mark Henry Cheap (ish) FI I'd go with a fresh 914 2.0 205... Mar 15 2017, 06:25 AM
Dave_Darling Oh, look! A spammer has joined us!
--DD Mar 15 2017, 09:56 AM
AZBanks The reason I asked is because I have a business pa... Mar 15 2017, 10:05 AM
Mark Henry
The reason I asked is because I have a business p... Mar 15 2017, 12:16 PM
Mueller
The reason I asked is because I have a business p... Mar 15 2017, 12:25 PM
914forme A few years ago I would have said sell it, spend t... Mar 15 2017, 02:50 PM
thelogo
A few years ago I would have said sell it, spend ... Mar 15 2017, 03:27 PM
Mueller
A few years ago I would have said sell it, spend... Mar 15 2017, 09:00 PM
thelogo So other then L-jet
You could say there is no ... Mar 16 2017, 12:11 AM
914forme Okay well if you insist.
Take a 1.7 or 1.8L, I wo... Mar 16 2017, 02:07 PM
thelogo
You can spend some seri... Mar 16 2017, 04:27 PM
Mueller True bumper sticker I just saw;
"I'd rat... Mar 16 2017, 06:00 PM
struckn Forgot to mention My 2V Weber has an Electric Chok... Mar 16 2017, 07:27 PM
mepstein If you find a more reliable, affordable, bolt on s... Mar 17 2017, 06:31 AM
thelogo
If you find a more reliable, affordable, bolt on ... Mar 17 2017, 03:45 PM
Mueller
If you find a more reliable, affordable, bolt on... Mar 17 2017, 05:58 PM
thelogo
[quote name='thelogo' post='2465093' date='Mar 17... Mar 17 2017, 08:21 PM
Mueller I'm not going to lie, if I stumbled upon a pai... Mar 17 2017, 09:14 PM
thelogo
I'm not going to lie, if I stumbled upon a pa... Mar 17 2017, 10:15 PM
rdauenhauer :agree: Mar 17 2017, 07:05 AM
thelogo :beer3:
Purr
Meow
:toke: :wavebye: Mar 17 2017, 08:25 PM
AZBanks My next engine upgrade.
http://www.oreillyauto.co... Mar 17 2017, 10:34 PM
Robnxious
http://www.oreillyauto.c... Mar 18 2017, 01:45 PM
rush Does anyone know of a available L jet system 4 sal... Mar 18 2017, 11:17 AM
Mark Henry
Does anyone know of a available L jet system 4 sa... Mar 18 2017, 12:48 PM
914forme Carbs,
Best drivability are Dellortos 36mm for yo... Mar 18 2017, 12:26 PM
thelogo
Carbs,
Best drivability are Dellortos 36mm for y... Mar 19 2017, 12:41 AM
mgphoto
[quote name='914forme' post='2465325' date='Mar 1... Mar 19 2017, 08:24 AM
914forme Class 5 is a different animal and you are correct,... Mar 19 2017, 09:08 AM
Dave_Darling If you do go with a single-carb setup, consider he... Mar 19 2017, 01:51 PM
porsche913b_sp :type: Mar 19 2017, 05:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:35 AM |
