FS: Rear brake caliper $75 (pass side I think), rear brake caliper |
pSquared |
Mar 8 2017, 02:35 PM
Newbie Group: Members Posts: 7 Joined: 23-April 06 Member No.: 5,913 |
GregAmy |
Mar 16 2017, 06:09 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Hi gents. As Phillip noted, I've already cut the deal with him. However, I think you're correct: I think it's a left one, and of course I actually need a right. So let me look at it when it arrives in a day or so and it may be back up for grabs...
"bcheney", what's the story there in the caliper spacers to allow use of a vented rotor...? |
rgalla9146 |
Mar 17 2017, 06:04 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Hi gents. As Phillip noted, I've already cut the deal with him. However, I think you're correct: I think it's a left one, and of course I actually need a right. So let me look at it when it arrives in a day or so and it may be back up for grabs... "bcheney", what's the story there in the caliper spacers to allow use of a vented rotor...? 10 mm spacers harvester from M front calipers. longer bolts too trim rotor diameter a bit trim end of through tube on trailing arm for caliper clearance shim caliper off mounts to center it over rotor |
Lo-Fi Version | Time is now: 8th June 2024 - 01:47 AM |
