| thelogo |
Mar 13 2017, 09:50 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
1st off the engine im going for in no way needs to
Be optimised for performance (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/stirthepot.gif) What is the best combo for just cool reliable running In socal heat . Im trying to stay clear of d jet (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bootyshake.gif) So carbs or i like cb performance f.i kit but know little actually about it . What Crank Pistons Rods Cam Cyclinder s Fuel delivery Etc should i be putting together and what kinda budget windfall Should i be prepared for . I know its a sickness but cant be that expensive? I will use a machine shop to build the motor That have extensive experience with type 4 So i know thats gonna cost me major $ (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/smoke.gif) Talk to me about proven engine combinatios (IMG:style_emoticons/default/beer3.gif) |
| mepstein |
Mar 17 2017, 06:31 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
If you find a more reliable, affordable, bolt on solution than factory FI, let me know. Until then, I'll be driving my d-jet 914.
| thelogo |
Mar 17 2017, 03:45 PM
| Mueller |
Mar 17 2017, 05:58 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
If you find a more reliable, affordable, bolt on solution than factory FI, let me know. Until then, I'll be driving my d-jet 914. If after 40+ years no one has come up with it Then maybe it doesn't exist. But those germans are some crafty bastards Basic descriptions.... Djet = analog or mechanical Modern EFI = digital trigger method: djet = mechanical points (replacements can be found NOS or replaced with digital points) modern = crank position sensor (these die and leave you stranded, hard to replace depending on location) air flow: djet = mps which uses a inductance via a bellows (brand new bellows assembly available) modern = hot wire or map (these are known to die, just replaced one in the family Volvo, wasn't cheap) tps: djet, mechanical sweeper, (I think NOS or maybe replacements available) modern = digital potonimeter (another item that is not 100% bullet proof) So everything fails at one point or another. If the Djet was "that" bad it wouldn't still be around on thousands of cars still and someone would have come up with a bolt on solution to replace it. (used on more than just 914's) |
| thelogo |
Mar 17 2017, 08:21 PM
If you find a more reliable, affordable, bolt on solution than factory FI, let me know. Until then, I'll be driving my d-jet 914. If after 40+ years no one has come up with it Then maybe it doesn't exist. But those germans are some crafty bastards Basic descriptions.... Djet = analog or mechanical Modern EFI = digital trigger method: djet = mechanical points (replacements can be found NOS or replaced with digital points) modern = crank position sensor (these die and leave you stranded, hard to replace depending on location) air flow: djet = mps which uses a inductance via a bellows (brand new bellows assembly available) modern = hot wire or map (these are known to die, just replaced one in the family Volvo, wasn't cheap) tps: djet, mechanical sweeper, (I think NOS or maybe replacements available) modern = digital potonimeter (another item that is not 100% bullet proof) So everything fails at one point or another. If the Djet was "that" bad it wouldn't still be around on thousands of cars still and someone would have come up with a bolt on solution to replace it. (used on more than just 914's) Great info ,,and thanks for dumbing it down so i can understand So it looks like im sticking with djet (IMG:style_emoticons/default/driving.gif) druck (IMG:style_emoticons/default/grouphug.gif) Until system failure Then ill be shopping for carbs and cam ..... (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/wub.gif) |
| Mueller |
Mar 17 2017, 09:14 PM
I'm not going to lie, if I stumbled upon a pair of carbs at a great price I'd probably jump on them and ditch what I have.
thelogo Money and motor options Mar 13 2017, 09:50 PM
thelogo Im looking for air cooled type 4
And basically... Mar 13 2017, 09:54 PM
Mueller I think McMark does the 2056 for about $5k , ... Mar 13 2017, 10:25 PM
thelogo
I think McMark does the 2056 for about $5k ,... Mar 13 2017, 10:54 PM
Dave_Darling A sock 1.7 should hold up just fine under darned n... Mar 13 2017, 10:29 PM
thelogo
A sock 1.7 should hold up just fine under darned ... Mar 13 2017, 10:47 PM
mgphoto
A sock 1.7 should hold up just fine under darned... Mar 14 2017, 09:39 AM
Dave_Darling
Do i rebuild a separate 1.7 and swap in
Wait ... Mar 14 2017, 10:58 AM
Chris914n6 Depends on what you are starting with.
66mm or 71... Mar 13 2017, 10:56 PM
Larmo63 Look for a complete 2.0 core, tear it down to a lo... Mar 13 2017, 10:57 PM
struckn Most people won't get what I'm saying but ... Mar 14 2017, 08:45 AM
mepstein Another option is a WTB request. Every year, many ... Mar 14 2017, 09:02 AM
Tom_T Since you're in SoCal ....
I'm not sure ... Mar 14 2017, 10:01 AM
thelogo :toke: :worship:
Sound advice d.d
Im happy ... Mar 14 2017, 04:41 PM
Mueller
:toke: :worship:
Sound advice d.d
Im happy... Mar 14 2017, 04:59 PM
thelogo
[quote name='thelogo' post='2464191' date='Mar 14... Mar 14 2017, 06:40 PM
thelogo
:toke: :worship:
Sound advice d.d
Im happ... Mar 14 2017, 06:42 PM
Mike D.
How do you fuck up a single carb :WTF:
You d... Mar 14 2017, 07:03 PM
thelogo
You ... Mar 14 2017, 10:00 PM
struckn
[quote name='Mike D.' post='2464240... Mar 16 2017, 01:27 PM
Mueller
[quote name='Mike D.' post='2464240... Mar 16 2017, 03:50 PM
914sgofast2 The answer to building a good engine with the Djet... Mar 16 2017, 05:03 PM
thelogo
The answer to building a good engine with the Dje... Mar 16 2017, 09:24 PM
struckn Alright I have to respond to the question above. H... Mar 16 2017, 05:11 PM
Mueller
[quote name='thelogo' post='2464191... Mar 14 2017, 08:09 PM
JamesM
:toke: :worship:
Sound advice d.d
Im happy... Mar 18 2017, 12:25 PM
thelogo Do or dont get me wrong djet is great
If they ... Mar 14 2017, 09:50 PM
Dave_Darling
Carbs are universally understood by mechanics al... Mar 14 2017, 10:23 PM
Mueller $3000 for the CB Performance EFI, and that do... Mar 14 2017, 10:31 PM
thelogo
$3000 for the CB Performance EFI, and that d... Mar 14 2017, 11:20 PM
Mueller
$3000 for the CB Performance EFI, and that ... Mar 14 2017, 11:44 PM
AZBanks How does the D-jet and other 914 FI systems pick u... Mar 14 2017, 11:50 PM
falcor75
How does the D-jet and other 914 FI systems pick ... Mar 15 2017, 12:28 AM
BeatNavy
How does the D-jet and other 914 FI systems pick ... Mar 15 2017, 03:52 AM
barefoot
How does the D-jet and other 914 FI systems pick ... Mar 15 2017, 05:35 AM
Mark Henry Cheap (ish) FI I'd go with a fresh 914 2.0 205... Mar 15 2017, 06:25 AM
Dave_Darling Oh, look! A spammer has joined us!
--DD Mar 15 2017, 09:56 AM
AZBanks The reason I asked is because I have a business pa... Mar 15 2017, 10:05 AM
Mark Henry
The reason I asked is because I have a business p... Mar 15 2017, 12:16 PM
Mueller
The reason I asked is because I have a business p... Mar 15 2017, 12:25 PM
914forme A few years ago I would have said sell it, spend t... Mar 15 2017, 02:50 PM
thelogo
A few years ago I would have said sell it, spend ... Mar 15 2017, 03:27 PM
Mueller
A few years ago I would have said sell it, spend... Mar 15 2017, 09:00 PM
thelogo So other then L-jet
You could say there is no ... Mar 16 2017, 12:11 AM
914forme Okay well if you insist.
Take a 1.7 or 1.8L, I wo... Mar 16 2017, 02:07 PM
thelogo
You can spend some seri... Mar 16 2017, 04:27 PM
Mueller True bumper sticker I just saw;
"I'd rat... Mar 16 2017, 06:00 PM
struckn Forgot to mention My 2V Weber has an Electric Chok... Mar 16 2017, 07:27 PM
thelogo
I'm not going to lie, if I stumbled upon a pa... Mar 17 2017, 10:15 PM
rdauenhauer :agree: Mar 17 2017, 07:05 AM
thelogo :beer3:
Purr
Meow
:toke: :wavebye: Mar 17 2017, 08:25 PM
AZBanks My next engine upgrade.
http://www.oreillyauto.co... Mar 17 2017, 10:34 PM
Robnxious
http://www.oreillyauto.c... Mar 18 2017, 01:45 PM
rush Does anyone know of a available L jet system 4 sal... Mar 18 2017, 11:17 AM
Mark Henry
Does anyone know of a available L jet system 4 sa... Mar 18 2017, 12:48 PM
914forme Carbs,
Best drivability are Dellortos 36mm for yo... Mar 18 2017, 12:26 PM
thelogo
Carbs,
Best drivability are Dellortos 36mm for y... Mar 19 2017, 12:41 AM
mgphoto
[quote name='914forme' post='2465325' date='Mar 1... Mar 19 2017, 08:24 AM
914forme Class 5 is a different animal and you are correct,... Mar 19 2017, 09:08 AM
Dave_Darling If you do go with a single-carb setup, consider he... Mar 19 2017, 01:51 PM
porsche913b_sp :type: Mar 19 2017, 05:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:35 AM |
