> Body work, to bondo or not to bondo~
mercdev
post Oct 25 2004, 10:33 PM
Read, search, then read some more
In removing the rear bumper from my car I notices that the PO had used mud on the rear right tail under the light housing (didn't bother to even sand it smooth so it was even with the surrounding area before painting). I've read other places that the factory even used mud to even out the bodywork prior to factory paint.
My question is, where on the car is this a bad idea (of course I know not to do it on the longs/hell hole areas)?
skline
post Oct 26 2004, 04:51 AM
Born to Drive
QUOTE(markd@mac.com @ Oct 26 2004, 01:45 AM)
Take out the expanding foam. At this point in your cars life it's more harm than good anyway.
But there's not a whole lot you can do in that area anyway. Access is very limited. Don't drill holes to pull it out or you'll cause more problems than it currently has. Only pull if you have a stud welder.
I bought a stud welder a few years back, the thing works awesome but it does take time to learn to do it right. Once you figure it out though, the sky is the limit on what you can do with it. Patience, that is the key.
mercdev   Body work   Oct 25 2004, 10:33 PM
McMark   You use body filler when the time it will take to ...   Oct 25 2004, 10:47 PM
sj914   In regards to the filler on the right rear below t...   Oct 26 2004, 12:54 AM
bob91403   Pound it out as much as you can, then use lead. Bo...   Oct 26 2004, 01:02 AM
sj914   You can't really pound it out. it's also ...   Oct 26 2004, 01:05 AM
bob91403   If you can't pound it, pull it. Just don't...   Oct 26 2004, 01:09 AM
sj914   Or pulling and pounding on your hootus would not b...   Oct 26 2004, 01:18 AM
McMark   Take out the expanding foam. At this point in you...   Oct 26 2004, 02:45 AM
skline   ALL METAL ...   Oct 26 2004, 05:17 AM
skline     Oct 26 2004, 05:21 AM
Brett W   BONDO SUCK BALLS!!!!!!...   Oct 26 2004, 06:35 AM
Lawrence   Bondo has gotten a bad rap over the years... since...   Oct 26 2004, 08:07 AM
URY914   LEAD!! :lol2: Come on, it's a 914. ...   Oct 26 2004, 08:19 AM
Root_Werks   There are different grades of filler(bondo) as I h...   Oct 26 2004, 08:23 AM
sanman   :agree: bondo is ok when worked properly   Oct 26 2004, 08:32 AM
morphenspectra   ...   Oct 26 2004, 08:55 AM
watsonrx13     Oct 26 2004, 09:50 AM
sanman   ALL METAL? where can I read about it or get it? Wh...   Oct 26 2004, 10:05 AM
tdgray   Absolutley All Metal ROCKS B) You should be abl...   Oct 26 2004, 11:00 AM
rhilgers   Evercoat Metal-2-Metal is easier to find in my are...   Oct 26 2004, 11:27 AM
Brett W   Guys there is nothing wrong with using a filler, w...   Oct 26 2004, 12:15 PM
Root_Werks   <...   Oct 26 2004, 02:01 PM
- Lo-Fi Version Time is now: 3rd July 2025 - 08:17 PM
