Clutch Tube Repair, How to do it? |
914 |
Mar 18 2017, 08:20 PM
Senior Member Group: Members Posts: 450 Joined: 26-December 02 Member No.: 19 Region Association: Southern California |
When I depress the clutch I here a clicking in the tunnel..The cable is maxed out with spacer nuts at the transmission end..What is the easiest way to do it as not to cut into the tunnel or weld..Is there a way?
Thanks,914 |
JeffBowlsby |
Mar 18 2017, 08:43 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Search on the term "clutch tube repair", you should get multiple threads here.
sixaddict |
Mar 19 2017, 07:17 AM
Senior Member Group: Members Posts: 805 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
I found them...finally figured search was google but I thought you meant this site.
It turned out to be on this site but found it through a google search. Like the idea of accessing through the bottom for track car that may be best .....Headed to the local 914 wizard ... Oh mine was diagnosed as bad pressure plate but getting ready to install new one but old looks just fine ...KA---CHING ! Search on the term "clutch tube repair", you should get multiple threads here. |
Lo-Fi Version | Time is now: 9th June 2024 - 08:43 PM |
