> Money and motor options, What is a realistic budget and parts list
thelogo
post Mar 13 2017, 09:50 PM
Group: Retired Members
1st off the engine im going for in no way needs to
Be optimised for performance (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/stirthepot.gif)
What is the best combo for just cool reliable running
In socal heat .
Im trying to stay clear of d jet (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bootyshake.gif)
So carbs or i like cb performance f.i kit but know little actually about it .
What
Crank
Pistons
Rods
Cam
Cyclinder s
Fuel delivery
Etc should i be putting together and what kinda budget windfall
Should i be prepared for .
I know its a sickness but cant be that expensive?
I will use a machine shop to build the motor
That have extensive experience with type 4
So i know thats gonna cost me major $
(IMG:style_emoticons/default/pray.gif)
(IMG:style_emoticons/default/smoke.gif)
Talk to me about proven engine combinatios (IMG:style_emoticons/default/beer3.gif)
914forme
post Mar 18 2017, 12:26 PM
Carbs,
Best drivability are Dellortos 36mm for your engine.
Next would be Webers, Italian, Spain, avoid all else unless you have to. These will be 40mm 44 and 48 are to big.
BTW, them Germans being crafty bastards happened to us carbs, on some of the European 914s. And I am not talking 914-6s I am talking -4s Some times you can find these also.
I would also not shy away from the single barrel dual carb units on a basic 1.7L build. Used a lot in the VW crowd, and a re a good little carb if your not looking for big numbers.
Here is a set of Redline Weber single carbs, $419 not sure of quality
And a good article on understanding VW carbs.
And Ebay Dell 36mm complete kit, there about, you will also need a fuel pump. I like the CB Performance Rotaries.
thelogo
post Mar 19 2017, 12:41 AM
QUOTE(914forme @ Mar 18 2017, 11:26 AM) *
Carbs,
I think the redlines you had the link for seems perfectly doable
But the photo showed the manifolds that didnt seem to be for a 914?
But being as my 1sr car was a baja bug and my neighbors builds class 5 bajas .
They always use a single carb dual throat weber over dual setup
With dual port curved manifold and the carb in a airbox
I guess its easier to protect 1 vs 2
No cross linkage
No multiple fuel lines
Since it will be taking a beating they avoid the dual setup
So i wouldn't be opposed to that setup
But any guy selling a single carb 914 manifold is probably a asshole (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/smash.gif)
mgphoto
post Mar 19 2017, 08:24 AM
"If there is a mistake it will find me"
QUOTE(thelogo @ Mar 18 2017, 11:41 PM) *
Carbs,
No cross linkage
You will hate the way it runs with FI cam...
This is a sports car not a bus.
thelogo   Money and motor options   Mar 13 2017, 09:50 PM
thelogo   Im looking for air cooled type 4 And basically...   Mar 13 2017, 09:54 PM
Mueller   I think McMark does the 2056 for about $5k , ...   Mar 13 2017, 10:25 PM
thelogo   I think McMark does the 2056 for about $5k ,...   Mar 13 2017, 10:54 PM
Dave_Darling   A sock 1.7 should hold up just fine under darned n...   Mar 13 2017, 10:29 PM
thelogo   A sock 1.7 should hold up just fine under darned ...   Mar 13 2017, 10:47 PM
mgphoto   A sock 1.7 should hold up just fine under darned...   Mar 14 2017, 09:39 AM
Dave_Darling   Do i rebuild a separate 1.7 and swap in Wait ...   Mar 14 2017, 10:58 AM
Chris914n6   Depends on what you are starting with. 66mm or 71...   Mar 13 2017, 10:56 PM
Larmo63   Look for a complete 2.0 core, tear it down to a lo...   Mar 13 2017, 10:57 PM
struckn   Most people won't get what I'm saying but ...   Mar 14 2017, 08:45 AM
mepstein   Another option is a WTB request. Every year, many ...   Mar 14 2017, 09:02 AM
Tom_T   Since you're in SoCal .... I'm not sure ...   Mar 14 2017, 10:01 AM
thelogo   :toke: :worship: Sound advice d.d Im happy ...   Mar 14 2017, 04:41 PM
Mueller   :toke: :worship: Sound advice d.d Im happy...   Mar 14 2017, 04:59 PM
thelogo   [quote name='thelogo' post='2464191' date='Mar 14...   Mar 14 2017, 06:40 PM
thelogo   :toke: :worship: Sound advice d.d Im happ...   Mar 14 2017, 06:42 PM
Mike D.   How do you fuck up a single carb :WTF: You d...   Mar 14 2017, 07:03 PM
thelogo   How do you fuck up a single carb :WTF: You ...   Mar 14 2017, 10:00 PM
struckn   [quote name='Mike D.' post='2464240...   Mar 16 2017, 01:27 PM
Mueller   [quote name='Mike D.' post='2464240...   Mar 16 2017, 03:50 PM
914sgofast2   The answer to building a good engine with the Djet...   Mar 16 2017, 05:03 PM
thelogo   The answer to building a good engine with the Dje...   Mar 16 2017, 09:24 PM
struckn   Alright I have to respond to the question above. H...   Mar 16 2017, 05:11 PM
Mueller   [quote name='thelogo' post='2464191...   Mar 14 2017, 08:09 PM
JamesM   :toke: :worship: Sound advice d.d Im happy...   Mar 18 2017, 12:25 PM
thelogo   Do or dont get me wrong djet is great If they ...   Mar 14 2017, 09:50 PM
Dave_Darling   Carbs are universally understood by mechanics al...   Mar 14 2017, 10:23 PM
Mueller   $3000 for the CB Performance EFI, and that do...   Mar 14 2017, 10:31 PM
thelogo   $3000 for the CB Performance EFI, and that d...   Mar 14 2017, 11:20 PM
Mueller   $3000 for the CB Performance EFI, and that ...   Mar 14 2017, 11:44 PM
AZBanks   How does the D-jet and other 914 FI systems pick u...   Mar 14 2017, 11:50 PM
falcor75   How does the D-jet and other 914 FI systems pick ...   Mar 15 2017, 12:28 AM
BeatNavy   How does the D-jet and other 914 FI systems pick ...   Mar 15 2017, 03:52 AM
barefoot   How does the D-jet and other 914 FI systems pick ...   Mar 15 2017, 05:35 AM
Mark Henry   Cheap (ish) FI I'd go with a fresh 914 2.0 205...   Mar 15 2017, 06:25 AM
Dave_Darling   Oh, look! A spammer has joined us! --DD   Mar 15 2017, 09:56 AM
AZBanks   The reason I asked is because I have a business pa...   Mar 15 2017, 10:05 AM
Mark Henry   The reason I asked is because I have a business p...   Mar 15 2017, 12:16 PM
Mueller   The reason I asked is because I have a business p...   Mar 15 2017, 12:25 PM
914forme   A few years ago I would have said sell it, spend t...   Mar 15 2017, 02:50 PM
thelogo   A few years ago I would have said sell it, spend ...   Mar 15 2017, 03:27 PM
Mueller   A few years ago I would have said sell it, spend...   Mar 15 2017, 09:00 PM
thelogo   So other then L-jet You could say there is no ...   Mar 16 2017, 12:11 AM
914forme   Okay well if you insist. Take a 1.7 or 1.8L, I wo...   Mar 16 2017, 02:07 PM
thelogo   Okay well if you insist. You can spend some seri...   Mar 16 2017, 04:27 PM
Mueller   True bumper sticker I just saw; "I'd rat...   Mar 16 2017, 06:00 PM
struckn   Forgot to mention My 2V Weber has an Electric Chok...   Mar 16 2017, 07:27 PM
mepstein   If you find a more reliable, affordable, bolt on s...   Mar 17 2017, 06:31 AM
thelogo   If you find a more reliable, affordable, bolt on ...   Mar 17 2017, 03:45 PM
Mueller   If you find a more reliable, affordable, bolt on...   Mar 17 2017, 05:58 PM
thelogo   [quote name='thelogo' post='2465093' date='Mar 17...   Mar 17 2017, 08:21 PM
Mueller   I'm not going to lie, if I stumbled upon a pai...   Mar 17 2017, 09:14 PM
thelogo   I'm not going to lie, if I stumbled upon a pa...   Mar 17 2017, 10:15 PM
rdauenhauer   :agree:   Mar 17 2017, 07:05 AM
thelogo   :beer3: Purr Meow :toke: :wavebye:   Mar 17 2017, 08:25 PM
AZBanks   My next engine upgrade. http://www.oreillyauto.co...   Mar 17 2017, 10:34 PM
Robnxious   My next engine upgrade. http://www.oreillyauto.c...   Mar 18 2017, 01:45 PM
rush   Does anyone know of a available L jet system 4 sal...   Mar 18 2017, 11:17 AM
Mark Henry   Does anyone know of a available L jet system 4 sa...   Mar 18 2017, 12:48 PM
914forme   Carbs, Best drivability are Dellortos 36mm for yo...   Mar 18 2017, 12:26 PM
thelogo   Carbs, Best drivability are Dellortos 36mm for y...   Mar 19 2017, 12:41 AM
mgphoto   [quote name='914forme' post='2465325' date='Mar 1...   Mar 19 2017, 08:24 AM
914forme   Class 5 is a different animal and you are correct,...   Mar 19 2017, 09:08 AM
Dave_Darling   If you do go with a single-carb setup, consider he...   Mar 19 2017, 01:51 PM
porsche913b_sp   :type:   Mar 19 2017, 05:01 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:31 AM
