Stumped, Fuse #8 issues |
srreality |
Mar 19 2017, 01:53 PM
Member Group: Members Posts: 73 Joined: 14-July 15 From: Colorado Member No.: 18,957 Region Association: None |
1973 914-4 - - - - My wipers, horn, cigarette lighter and hot air fan won't work. I'm getting no current at fuse #8. I've replaced the wiper switch, checked the ground, cleaned all the connections at the bottom of the steering column and replaced the horn relay, still nada. I'm an amateur at this, especially electrical current flow. My turn signals work, which to me means I'm getting current to/through that switch. But no current out of the wiper switch with the key on and wiper switch on. What am I missing?
Tom |
Mar 20 2017, 05:08 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
srreality,
The power to fuse #8 comes thru the fresh air relay, J-13. Wiggle it around while the radio is on and see if you get intermittent contact. If so, you will need to clean the contacts of the socket and the prongs on the relay. You can spread the prongs very slightly to help get a good contact. Tom |
Lo-Fi Version | Time is now: 4th June 2024 - 10:19 AM |
