euro914er |
Newbie ![]() Group: Members Posts: 17 Joined: 28-September 16 From: Uk Member No.: 20,442 Region Association: England ![]() |
Hi everyone,
I'm a new UK owner - circa 6 months - of a 1.8L, 1974 in chrome yellow. The car is ex west coast, then was imported into the UAE by its PO around 4 years ago. There it was stripped down, repainted and reupholstered. The engine was put back in, but never recommissioned. The PO then came back to the UK about 2 years but never got around to connecting everything back up - all the vac hoses were missing, fuel lines gone and lots of wires go nowhere. Well I've sorted all of this and a few weeks back I attempted to turn her over. I was met with a "click" and after a quick google, internet wisdom pointed towards the solenoid. This was replaced and now the click has turned into a thunk. Jacking the wheel up and putting it into fifth, I can just about get the wheel to turn 180 degrees before I reach a hard stop. Plugs are out and diesel has been poured into to each cylinder. BTW - some leaks out of one cylinder - should it be doing that? I'm now at the limit of my knowledge - some posts suggest its an earth strap problem - others suggest something more serious such as a stuck valve. The drivers side valve cover is over and all looks normal (according to a colleague). The passenger side will be more tricky as its deeply buried. So what does the collective feel should be my next move? I've resisted pulling out the engine but I have a feeling I'm head that way. As you can see, she's mint apart from a sick engine Attached thumbnail(s) ![]() |
euro914er |
Hi all,
just to update you. Last weekend I dropped the engine - and actually quite enjoyed the process. However my enjoyment was short lived when I managed to get the driver's side head off - carnage. Warning: The following images are upsetting! I've subsequently been told a valve seat slipped, got trapped and then smashed to bits. I'm also told that the head is salvageable but it may be more cost effective to source a re-con one. Which leads me to another question. There are two different numbers on the cylinder block. The number under the rocker bar is cast and reads: 021131371S. The number on the outside near the inlet air manifold is etched and reads: 022101372C To recap, this is a 1.8 with engine code EC. Any suggestions as to why these are different? There is a small VW stamp after the engine number. Thanks ![]() |
Lo-Fi Version | Time is now: 15th July 2025 - 04:07 AM |
