> Engine won't crank - earth or more serious?
euro914er
post Feb 28 2017, 07:28 AM
Region Association: England
Hi everyone,
I'm a new UK owner - circa 6 months - of a 1.8L, 1974 in chrome yellow. The car is ex west coast, then was imported into the UAE by its PO around 4 years ago. There it was stripped down, repainted and reupholstered. The engine was put back in, but never recommissioned. The PO then came back to the UK about 2 years but never got around to connecting everything back up - all the vac hoses were missing, fuel lines gone and lots of wires go nowhere. Well I've sorted all of this and a few weeks back I attempted to turn her over. I was met with a "click" and after a quick google, internet wisdom pointed towards the solenoid. This was replaced and now the click has turned into a thunk. Jacking the wheel up and putting it into fifth, I can just about get the wheel to turn 180 degrees before I reach a hard stop. Plugs are out and diesel has been poured into to each cylinder. BTW - some leaks out of one cylinder - should it be doing that?
I'm now at the limit of my knowledge - some posts suggest its an earth strap problem - others suggest something more serious such as a stuck valve. The drivers side valve cover is over and all looks normal (according to a colleague). The passenger side will be more tricky as its deeply buried.
So what does the collective feel should be my next move? I've resisted pulling out the engine but I have a feeling I'm head that way. As you can see, she's mint apart from a sick engine
euro914er
post Mar 21 2017, 07:31 AM
More carnage
euro914er   Engine won't crank - earth or more serious?   Feb 28 2017, 07:28 AM
bdstone914   Need a little more info to help you. Does anythin...   Feb 28 2017, 08:21 AM
euro914er   Thanks for the welcome. Battery is brand new. Wit...   Feb 28 2017, 01:54 PM
ottox914   Pulling the plugs should make it easier to turn ov...   Feb 28 2017, 02:03 PM
euro914er   Thanks ottox914. Plugs are pulled and the driver...   Feb 28 2017, 02:31 PM
timothy_nd28   I have a bad feeling that something dropped down y...   Feb 28 2017, 02:47 PM
euro914er   I'm scared to asked - what was the outcome?   Feb 28 2017, 03:14 PM
Perry Kiehl   With the spark plugs out you should be able to tur...   Feb 28 2017, 04:05 PM
euro914er   Thanks for that advice..I'll give the borescop...   Feb 28 2017, 04:58 PM
euro914er   Hi all, managed to get rocker covers off at the we...   Mar 6 2017, 07:26 AM
McMark   Rotate the engine while watching the rockers. You...   Mar 6 2017, 07:35 AM
Bartlett 914   I had a similar to a motor that had been sitting a...   Mar 6 2017, 08:04 AM
Bob L.   Have you checked the impeller fan for obstruction?   Mar 6 2017, 09:38 AM
euro914er   Fan 'feels' clear but I've just ordere...   Mar 7 2017, 06:47 AM
euro914er   Hi all, just to update you. Last weekend I dropp...   Mar 21 2017, 07:30 AM
euro914er   More carnage   Mar 21 2017, 07:31 AM
euro914er   Suring surgery   Mar 21 2017, 07:32 AM
Vacca Rabite   Well, better to know and get it fixed. The piston ...   Mar 21 2017, 07:46 AM
- Lo-Fi Version Time is now: 15th July 2025 - 03:37 AM
