Hammer920 |
It's a Learning Experience ![]() ![]() Group: Members Posts: 83 Joined: 27-April 04 From: Levelland, TX Member No.: 1,989 ![]() |
Started yesterday removing all the bolts and nuts on the block, Haynes stated there are 24. I have removed all but the 6 - 17mm long bolts, have removed the nuts but the bolts will not come all the way out, and I don't want to screw them up, did take a wooden dowel and a rubber mallet and tried to tap those out but they get stuck about half way. Do these need to come all the way out or part of the way? I have tapped around the right side of the block, block is splitting on the front and bottom on both ends but on the top on the transmissin end is not splitting there are no bolts there to keep it from splitting. Any Suggestions Would be appreciated?
Also I bought some 1.7 90mm pistons and jugs (new) they are made by Cofap part #'s 022 198 075, J036D, 01 022 19875, dommed pistons. Will these pistons and jugs be good enough for daily driver. (IMG:style_emoticons/default/smile.gif) And By the way everytime I start back to work on this it rains have to stop put all the stuff back in storage shead and wait. (IMG:style_emoticons/default/headbang.gif) |
Hammer920 |
(IMG:style_emoticons/default/smile.gif) Thanks I have not removed the 6 bolts just the nuts all 6 of them are still in the block just tapped on them not har would not come out left well enough alone will try to finish splitting it today is comming apart except top of transmission has split a little will continue to tap on it.
thanks again for the help |
Lo-Fi Version | Time is now: 22nd August 2025 - 02:42 AM |
