911 front strut issue |
mepstein |
Mar 25 2017, 12:21 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I purchased some Bilstein inserts for some Boge 3" 911 front struts. Everything fits except the top cap is a couple mm shy of screwing down. Anyone run into this issue? I don't know if I need a different top cap or different insert. When I take the insert out it screws down all the way but the insert is a couple mm to tall when it's in the strut. ???
Attached thumbnail(s) |
mepstein |
Mar 25 2017, 01:52 PM
Both sides are the same. Won't tighten any further. They get to that point and then just stop. I always put a little oil in the bottom but not enough to change the height.
mb911 |
Mar 25 2017, 01:55 PM
914 Guru Group: Members Posts: 6,881 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Both sides are the same. Won't tighten any further. They get to that point and then just stop. I always put a little oil in the bottom but not enough to change the height. Mine was actually bleed through weld from the factory that made it right and ironically they are boge as well. |
Lo-Fi Version | Time is now: 8th June 2024 - 07:26 AM |
