| iankarr |
Mar 26 2017, 09:25 AM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,600 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
Hi Guys,
So...my (new to me) 74 2.0 FI was idling great and running pretty well, except after warm it would occasionally experience a loss of power at about 3000K. Last weekend I took the dizzy out to clean and lube the plates. Also installed a pertronix and flame thrower coil. Started it up and ran like crap and uber rich. Then realized I forgot to connect the MPS hose. duh. Did that and it started up ok. It was late, so I left the car till this weekend to get the timing dialed in. OK, so I start it today and hear this tapping racket and the engine feels like it's only running on 3 cylinders. Pulled plug wires one at a time, and it seems all are contributing. Pulled the valve covers to see if that's where the racket was coming from and figured it was a good idea to make sure everything was properly adjusted anyway. Nothing LOOKS weird, but if I pull backwards on the #2 intake rocker, it will move about 1/4" towards me. Let it go and it returns back to contacting the valve stem. I know it isn't normal, but before I tear into things, I thought I'd check with the brain trust.Bent rod? Beginnings of dropped valve? From what I can tell, the POs didn't drive this car much, so I wouldn't be surprised that all this new activity is exposing weaknesses.... Thanks! |
| Mikey914 |
Mar 26 2017, 11:09 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,781 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Well if you have 1/4" i would suspect that you at least need to adjust the valve clearance. Ans another member mentioned there coukd be an issue with the rocker mount. Id remove the rocker assembly and inspect the mout. If its ok assemble do a complete valve adjust and start it up.
Had a kind of simular situation with my sons car. Started making noise and lost power. Was running on 3 cylinders. Turned out whoever installed the tube retainer spring didn't do it correctly and it rubbed on one push rod. It started wearing through until it actually cut in half. Leaving about 1/4" play. It wasn't evident right away. The mechanic he went to said dropped seat, so i helped him retrieve the car. When we got it home and disassembled that's what we found. Replaced the rod, did a valve adjust and drove it runnibg perfectly until he wrecked the car abound 20k later. Hope this is what happened here as it was an easy fix |
cuddyk This can't be good. Mar 26 2017, 09:25 AM
Tbrown4x4 Which direction are you pulling it? Are you slidin... Mar 26 2017, 09:29 AM
cuddyk Away from the valve, towards me. None of the other... Mar 26 2017, 09:33 AM
Krieger A long time ago I had a car with 2.0 heads that ov... Mar 26 2017, 09:47 AM
r_towle Have you considered you may have hydraulic lifters... Mar 26 2017, 10:53 AM
stugray
....some of them you cannot totally remove the tu... Mar 26 2017, 11:01 AM
r_towle Btw, that head is way to clean.... Mar 26 2017, 10:57 AM
Tbrown4x4 I was thinking hydraulic lifters too. There is a w... Mar 26 2017, 10:57 AM
r_towle
Well if you have 1/4" i would suspect that y... Mar 26 2017, 11:22 AM
cuddyk Thanks guys.
Unfortunately this car came with no ... Mar 26 2017, 11:28 AM
injunmort mine made a similar intermittent racket. the engin... Mar 26 2017, 11:42 AM
Mark Henry Springing back like that is odd and I'm wonder... Mar 26 2017, 12:16 PM
rgalla9146 There is no spring in a 2.0 lifter.
As has been ... Mar 26 2017, 12:16 PM
zipedadoo What if the cam lobe was gone for that valve? Prob... Mar 26 2017, 12:40 PM
cuddyk Engine code stamp looks normal. And it appears the... Mar 26 2017, 12:54 PM
Tbrown4x4 You're this deep. I would pull the tube and fi... Mar 26 2017, 01:08 PM
cuddyk
You're this deep. I would pull the tube and f... Mar 26 2017, 01:21 PM
Tbrown4x4 I would switch to solid myself. I don't have a... Mar 26 2017, 01:32 PM
rgalla9146 Maybe it's just that one ?.....best to check .... Mar 26 2017, 02:28 PM
cuddyk Just checked the #2 exhaust lifter with the borosc... Mar 26 2017, 03:46 PM
rgalla9146
Just checked the #2 exhaust lifter with the boros... Mar 26 2017, 05:04 PM
r_towle It could be fine if you let the oil get warm and f... Mar 26 2017, 05:16 PM
cgnj CrMO for sure, Cam any ones guess. I"d go to ... Mar 26 2017, 05:25 PM
cuddyk Thanks guys. Doing some research on conversion to ... Mar 26 2017, 07:03 PM
Mark Henry You absolutely have to change the cam to go to sol... Mar 27 2017, 12:03 AM
Tbrown4x4 I was more worried about new lifters on an old cam... Mar 27 2017, 04:36 AM
cuddyk Much appreciated, World.
If this is a cam change ... Mar 27 2017, 07:27 AM
cuddyk Just a quick update...
Turns out the rough runnin... Apr 1 2017, 11:22 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 11:20 AM |
