| Seelenfan |
Mar 29 2017, 08:53 PM
Newbie ![]() Group: Members Posts: 41 Joined: 12-February 17 From: Phoenix AZ Member No.: 20,836 Region Association: Southwest Region |
I know you guys probably get tired of electrical questions.. I have been reading and searching. But can find the answers..
It's a 73. I know the year can make a difference.. I don't have power at my brake pedal switch. The switch works as I tested it with my multimeter. I attached my meter to the lead with 2 wires and poked the fuse panel. (Batt disconnected) it gets continuety on 8 out of 12 fuses.. this is confusing to me. So I checked the other wire that plugs into the switch, same results.. Attached is a pic of a relay stuffed in the dash. This buzzes. Is it supposed to buzz? I thought the buzzer was saposed to be under the pass seat. All 4 round 5 pin relays on the back of the fuse panel are good. I tested them in a known good plug. Another issue is that I have power to # 3 4 5 6 7 8 9 10 11 12 with the key on and headlights on. But no power to #1 or 2. Headlights come up, light up but no high beam.. so where does #1 and 2 get it's power from? Attached thumbnail(s) |
| jcd914 |
Mar 29 2017, 10:57 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,098 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
And fuse S1 & S2 are your high beam fuses, it will only have power when headlights are on and high/low relay is switch to high beams.
I'm in the middle of wiring work on my 914 right now. (Yes Rob, I'm working on my car) Jim |
Seelenfan Electrical... Mar 29 2017, 08:53 PM
jcd914 Brake light switch should get power from fuse S9 v... Mar 29 2017, 10:52 PM
ConeDodger
And fuse S1 & S2 are your high beam fuses, it... Mar 29 2017, 11:15 PM
jcd914 My harness had a short and I had melted wires and ... Mar 29 2017, 11:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th November 2026 - 07:55 PM |
