| McLovin |
Mar 30 2017, 11:20 AM
Member ![]() ![]() Group: Members Posts: 110 Joined: 31-August 16 From: Tallahassee, FL Member No.: 20,360 Region Association: South East States |
Hey guys,
After almost six months of hanging out here, from selling my old VW, to making a downpayment on a 914, my car was finally delivered last night! However, during the test drive there were some issues with the car, so I haven't made my final payment yet. Instead, I'm in the middle of a prolonged inspection period because of what popped up on the test drive. I'm fairly confident that I'll keep the car because it's virtually rust free, has nice paint and interior, and the engine seems to run and drive well. That being said, main problems it has that need to be addressed are as follows: 1. The alternator light won't go out. I know how to trouble shoot this. The car appears to be charging regardless, so it might be a loose fuse. I can figure this one out. 2. When I drove it, the brake appears to be sticking. The front calipers were giving the seller problems and it was thought these were lubricated to where they don't stick, but apparently not. I've never rebuilt one, and I'm not thrilled about doing it, so I'll probably buy some rebuilt calipers. But I need to inspect them first. 3. Lastly, I have oil leaks. One appears to be from that plate near the drain plug. I've seen this before on VWs and it's not a big deal. However, when I went for about a 1-mile test drive, when I stopped, a bunch of smoke came forward out of the car. My initial thought is this might be oil coming off the valve cover gasket onto the manifold. But what else could it be? What are some common ("makes a lot of smoke") oil leaks on these little gems? #2 and #3 are the items that give me a little bit of a stomach ache. If the picture shows up, its not very good because it was in my garage late at night. I plan to pull the car out this weekend and work on it...I'll get new pix then. Thanks in advance, Mclovin ![]() |
| Chris914n6 |
Mar 30 2017, 02:07 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,524 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
3. Likely the valve cover gaskets or push rod tube seals leaking onto the exhaust pipes. Or spilt oil from refill. Could turn into a full days work but definitely not a deal breaker.
2. Could be a couple of things, all minor. Pinched piston seal, old and swollen hose, old fluid. Won't know until you get in there. 1. Don't rule out wired wrong. |
McLovin Finally got my '75 914 Mar 30 2017, 11:20 AM
Frankvw Great ! Alternator max 250 $ for a new/re... Mar 30 2017, 11:34 AM
76-914 The caliper rebuild is simple if you buy the kit f... Mar 30 2017, 12:11 PM
Dave_Darling No alternator light means the system is not chargi... Mar 30 2017, 02:03 PM
McLovin
3. Likely the valve cover gaskets or push rod tub... Mar 30 2017, 03:00 PM
JawjaPorsche
3. Likely the valve cover gaskets or push rod tu... Mar 30 2017, 03:29 PM
mtndawg It's a really good sign if it is virtually rus... Mar 30 2017, 02:30 PM
McLovin Thanks for the suggestions. Tonight I verified my... Mar 30 2017, 09:23 PM
Rand
I was sitting in my car in the driver's seat,... Mar 30 2017, 09:26 PM
McLovin
I was sitting in my car in the driver's seat... Mar 30 2017, 10:30 PM
Chris914n6
Thanks for the suggestions. Tonight I verified m... Mar 31 2017, 05:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th March 2026 - 11:49 PM |
