| 914 RZ-1 |
Mar 30 2017, 06:47 PM
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I've edited in bold red.
This is bit long, but I've numbered everything, so just answer the number(s) you want/can. My 1.7L with a Pertronix (everything else is stock) does not seem to run as well as I think it should. Seems to be missing/runs a little rough. It will hesitate and surge just a little, not accelerate smoothly, when I press the gas. This is less of a problem when it is warm. Lately it's been hard to start. It would crank and want to catch, but took awhile. Today, it just wouldn't start, even though it cranked just fine. I'm thinking I need to check: 1. Fuel injectors. I've replaced 2, may need to replace the other 2. They all work just fine. Used a 9v mattery and some wires t osee if they "clicked". 2. Coil: the one on there looks like the original. Do these wear out? I've seen posts on how to test them, but I've seen conflicting numbers for results: + to - 0.75-0.81 Ohms, 3 Ohms, and + to distributor output 8-12 Ohms and 10,000-11,000 Ohms. Big difference! Replaced with a Bosch Blue. I checked the voltage on the old one from terminal 15 to ground and got 10.7V 3. Distributor cap: How do I tell if this is worn out? Replaced. I did keep the old one, though. 4. Rotor: How do I tell if this is worn out? Replaced. I did keep the old one, though. 5.Wires and Plugs: mine could be old, but how do I tell if these are worn out? Replaced. I did keep the old ones, though. On the plugs, they were WR7CP with a 0.023-0.025 gap. I replaced them with WR7CC+ with a 0.028 gap. [color=#000000]I'm assuming I don't need to look at points or the condenser since I have electronic ignition. 6. Check fuel pressure. I just replaced a bad pump. I usually turn the key to start the pump 3 times before firing the engine. This doesn't fry anything does it? Fuel pressure is fine. Made a gauge out of a swimming pool pump gauge and some fuel lines and hose clamps. Car starts right up without any priming! 7. Anything else I should check? a. I bought a new fuel filter. Need to install it. b. need to clean the fuel sending unit. c. checked the timing. It was fine d. need to check the ground strap e. I replaced a hose from the plenum to the fuel rail (old one leaked) and when I drained the gas out, it had black grit in it. I'm guessing this is crumbled fuel line. I've also thought of just replacing everything above, but I'd like to at least figure out what the problem is. I've had the car about a year and a half and put about 3,000 miles on it. I drive it at least once a week. I think I'm still in the "shakedown cruise" stage, since it sat for 20 years and the PO just got it running to sell it. Car now starts right up and runs great! |
| 914_teener |
Mar 31 2017, 11:52 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Always have ALL the injectors checked for flow and pattern.
Several places do this and it isn.t expensive. Inspect your whole fuel system if the car has been sitting.....from the condition and cleanliness of the fuel tank to the fuel lines. |
914 RZ-1 engine seems to not run right Mar 30 2017, 06:47 PM
mgphoto
This is bit long, but I've numbered everythin... Mar 30 2017, 10:46 PM
cgnj Hi,
Had the car for a year and with unknown mainte... Mar 31 2017, 05:40 AM
mgphoto Yes forgot the valve adjustment. Mar 31 2017, 10:15 AM
914 RZ-1
Always have ALL the injectors checked for flow an... Apr 1 2017, 02:55 PM
Mikey914 Check t he resistance on the cht at room temp (bef... Mar 31 2017, 01:17 PM
914 RZ-1
Check t he resistance on the cht at room temp (be... Apr 1 2017, 03:04 PM
914 RZ-1 Here is a pic of the cap:
Apr 1 2017, 10:38 AM
914 RZ-1 Rotor pic:
Apr 1 2017, 10:39 AM
914 RZ-1 Pic of end of wire that goes in distributor:
Apr 1 2017, 10:41 AM
914 RZ-1 I've checked the following so far:
1. Fuel in... Apr 1 2017, 10:49 AM
76-914 2. - youtube has a good video on "How to chec... Apr 1 2017, 12:18 PM
914 RZ-1 2. I figured out how to check the #15 terminal (on... Apr 1 2017, 02:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 5th October 2026 - 08:45 AM |
