| falcor75 |
Apr 1 2017, 07:51 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia
How deep should it be installed? Flush with the outer flange or flush with the inner flanfe??
| forrestkhaag |
Apr 1 2017, 09:41 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
In order to seal properly, (and I just did mine a week or two ago - and it doesn't leak... for now...) I used a smooth pipe long enough to straddle the shaft and tapped it "home" to mate the seal with the inner case area. If memory serves me, it went in another eighth inch from where your picture shows it to be. Someone else may have a different experience.
(IMG:style_emoticons/default/beerchug.gif) Attached image(s)
falcor75 Gearbox input shaft seal installation? Apr 1 2017, 07:51 AM
falcor75 RE: Gearbox input shaft seal installation? Apr 1 2017, 07:52 AM
BeatNavy The primary goal is to just get the seal deep enou... Apr 1 2017, 10:11 AM
mtndawg
The primary goal is to just get the seal deep eno... Apr 1 2017, 04:08 PM
BeatNavy
The primary goal is to just get the seal deep en... Apr 1 2017, 05:05 PM
porschetub Had this tool from VW days perfect for installing ... Apr 1 2017, 01:57 PM
914Sixer I can add a picture of what the seal looks like. ... Apr 1 2017, 09:26 PM
BeatNavy Here's a couple of pics of the type Mark got a... Apr 2 2017, 08:00 AM
falcor75 Well I got a pretty obvious signal from the gearbo... Apr 22 2017, 10:08 AM
Bartlett 914
Well I got a pretty obvious signal from the gearb... Apr 22 2017, 05:02 PM
dangrouche I would always smear of lube to prevent tearing of... Apr 22 2017, 10:22 AM
falcor75 I made a tool that will work, lasercut a washer th... Apr 22 2017, 10:50 AM
The Cabinetmaker You must clean and smooth the inside of the case. ... Apr 23 2017, 07:50 AM
falcor75 Car is back together and testdriven around 20 km. ... Apr 23 2017, 08:42 AM
SteveNMaine Can you use the guide tube to press in the seal? May 6 2025, 07:08 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd June 2026 - 01:28 AM |
