> This can't be good., rocker movement - help diagnosing before tearing
iankarr
post Mar 26 2017, 09:25 AM
Hi Guys,
So...my (new to me) 74 2.0 FI was idling great and running pretty well, except after warm it would occasionally experience a loss of power at about 3000K. Last weekend I took the dizzy out to clean and lube the plates. Also installed a pertronix and flame thrower coil. Started it up and ran like crap and uber rich. Then realized I forgot to connect the MPS hose. duh. Did that and it started up ok. It was late, so I left the car till this weekend to get the timing dialed in.
OK, so I start it today and hear this tapping racket and the engine feels like it's only running on 3 cylinders. Pulled plug wires one at a time, and it seems all are contributing.
Pulled the valve covers to see if that's where the racket was coming from and figured it was a good idea to make sure everything was properly adjusted anyway. Nothing LOOKS weird, but if I pull backwards on the #2 intake rocker, it will move about 1/4" towards me. Let it go and it returns back to contacting the valve stem. I know it isn't normal, but before I tear into things, I thought I'd check with the brain trust.Bent rod? Beginnings of dropped valve?
From what I can tell, the POs didn't drive this car much, so I wouldn't be surprised that all this new activity is exposing weaknesses....
Thanks!
iankarr
post Apr 1 2017, 11:22 AM
Just a quick update...
Turns out the rough running was due to a bad spark plug cable (old school NGK with cracked shield). The pertronix is rock solid and the noisy hydraulic lifter pumped up with oil and quieted down after about 5 minutes of driving. All great now. Nice to know I don't have to split the case right at the beginning of the season.
Thanks again to the great engine forensic detectives!
cuddyk   This can't be good.   Mar 26 2017, 09:25 AM
Tbrown4x4   Which direction are you pulling it? Are you slidin...   Mar 26 2017, 09:29 AM
cuddyk   Away from the valve, towards me. None of the other...   Mar 26 2017, 09:33 AM
Krieger   A long time ago I had a car with 2.0 heads that ov...   Mar 26 2017, 09:47 AM
r_towle   Have you considered you may have hydraulic lifters...   Mar 26 2017, 10:53 AM
stugray   ....some of them you cannot totally remove the tu...   Mar 26 2017, 11:01 AM
r_towle   Btw, that head is way to clean....   Mar 26 2017, 10:57 AM
Tbrown4x4   I was thinking hydraulic lifters too. There is a w...   Mar 26 2017, 10:57 AM
Mikey914   Well if you have 1/4" i would suspect that yo...   Mar 26 2017, 11:09 AM
r_towle   Well if you have 1/4" i would suspect that y...   Mar 26 2017, 11:22 AM
cuddyk   Thanks guys. Unfortunately this car came with no ...   Mar 26 2017, 11:28 AM
injunmort   mine made a similar intermittent racket. the engin...   Mar 26 2017, 11:42 AM
Mark Henry   Springing back like that is odd and I'm wonder...   Mar 26 2017, 12:16 PM
rgalla9146   There is no spring in a 2.0 lifter. As has been ...   Mar 26 2017, 12:16 PM
zipedadoo   What if the cam lobe was gone for that valve? Prob...   Mar 26 2017, 12:40 PM
cuddyk   Engine code stamp looks normal. And it appears the...   Mar 26 2017, 12:54 PM
Tbrown4x4   You're this deep. I would pull the tube and fi...   Mar 26 2017, 01:08 PM
cuddyk   You're this deep. I would pull the tube and f...   Mar 26 2017, 01:21 PM
Tbrown4x4   I would switch to solid myself. I don't have a...   Mar 26 2017, 01:32 PM
rgalla9146   Maybe it's just that one ?.....best to check ....   Mar 26 2017, 02:28 PM
cuddyk   Just checked the #2 exhaust lifter with the borosc...   Mar 26 2017, 03:46 PM
rgalla9146   Just checked the #2 exhaust lifter with the boros...   Mar 26 2017, 05:04 PM
r_towle   It could be fine if you let the oil get warm and f...   Mar 26 2017, 05:16 PM
cgnj   CrMO for sure, Cam any ones guess. I"d go to ...   Mar 26 2017, 05:25 PM
cuddyk   Thanks guys. Doing some research on conversion to ...   Mar 26 2017, 07:03 PM
Mark Henry   You absolutely have to change the cam to go to sol...   Mar 27 2017, 12:03 AM
Tbrown4x4   I was more worried about new lifters on an old cam...   Mar 27 2017, 04:36 AM
cuddyk   Much appreciated, World. If this is a cam change ...   Mar 27 2017, 07:27 AM
cuddyk   Just a quick update... Turns out the rough runnin...   Apr 1 2017, 11:22 AM
- Lo-Fi Version Time is now: 1st May 2026 - 11:21 AM
