| falcor75 |
Apr 1 2017, 07:51 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia
How deep should it be installed? Flush with the outer flange or flush with the inner flanfe??
| 914Sixer |
Apr 1 2017, 09:26 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,503 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
I can add a picture of what the seal looks like. I might have one. Mark at 914Rubber has one. He had planned to make them a some point.
falcor75 Gearbox input shaft seal installation? Apr 1 2017, 07:51 AM
falcor75 RE: Gearbox input shaft seal installation? Apr 1 2017, 07:52 AM
forrestkhaag In order to seal properly, (and I just did mine a ... Apr 1 2017, 09:41 AM
BeatNavy The primary goal is to just get the seal deep enou... Apr 1 2017, 10:11 AM
mtndawg
The primary goal is to just get the seal deep eno... Apr 1 2017, 04:08 PM
BeatNavy
The primary goal is to just get the seal deep en... Apr 1 2017, 05:05 PM
porschetub Had this tool from VW days perfect for installing ... Apr 1 2017, 01:57 PM
BeatNavy Here's a couple of pics of the type Mark got a... Apr 2 2017, 08:00 AM
falcor75 Well I got a pretty obvious signal from the gearbo... Apr 22 2017, 10:08 AM
Bartlett 914
Well I got a pretty obvious signal from the gearb... Apr 22 2017, 05:02 PM
dangrouche I would always smear of lube to prevent tearing of... Apr 22 2017, 10:22 AM
falcor75 I made a tool that will work, lasercut a washer th... Apr 22 2017, 10:50 AM
The Cabinetmaker You must clean and smooth the inside of the case. ... Apr 23 2017, 07:50 AM
falcor75 Car is back together and testdriven around 20 km. ... Apr 23 2017, 08:42 AM
SteveNMaine Can you use the guide tube to press in the seal? May 6 2025, 07:08 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd June 2026 - 12:09 AM |
