clapeza |
Member ![]() ![]() Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States ![]() ![]() |
Getting closer to getting the FI back in my '70 1.7, but I have a couple questions about the FI wiring harness. Using Jeff Bowlsby's diagrams, I have ID'd what everything connects to, but I can't tell which injector connector goes to which cylinder's injector. The diagram labels one on each side as "blue", but I'm having a little trouble telling the difference. Any other way to tell, like relative length from main harness?
Also, what is the proper routing of the wiring harness? Does it go across the front of the engine, straight across the middle, or towards the back? I'm sure much will reveal itself as I put it in the car, but a little guidance is appreciated. I've also combined about 4 of Jeff's excellent diagrams into one master "Relay Board" diagram. With his permission, I'll post it. Thanks! Chester |
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,954 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
Start by laying out the harness with what you know goes where. Obviously you know which one is the ECU connector. Start there, then go toward the back hooking up the MPS connections, the CHT connection, and the injectors on the passenger side. Go on the back side of the engine, hooking up the multi-point grounds and the throttle body / T1 sensors. Now you're on the driver's side, and you should be able to hook up the injectors on that side and the connections to the relay board.
At least that's how I recall doing it on my 2.0 (routing mostly around the back of the engine). It should reveal itself, as you say, once you start laying it out. It should be fairly apparent which connectors go where. |
Lo-Fi Version | Time is now: 11th July 2025 - 07:06 AM |
