> Djet FI Harness questions, Identifying injector connectors, routing of harness
clapeza
post Apr 2 2017, 10:27 AM
Getting closer to getting the FI back in my '70 1.7, but I have a couple questions about the FI wiring harness. Using Jeff Bowlsby's diagrams, I have ID'd what everything connects to, but I can't tell which injector connector goes to which cylinder's injector. The diagram labels one on each side as "blue", but I'm having a little trouble telling the difference. Any other way to tell, like relative length from main harness?
Also, what is the proper routing of the wiring harness? Does it go across the front of the engine, straight across the middle, or towards the back? I'm sure much will reveal itself as I put it in the car, but a little guidance is appreciated.
I've also combined about 4 of Jeff's excellent diagrams into one master "Relay Board" diagram. With his permission, I'll post it.
Thanks!
Chester
post Apr 2 2017, 10:51 AM
914-6 GT in waiting
If you are putting an older harness back into an engine compartment, they almost fall into place and the wire lengths make it almost impossible to attach to the wrong injector. The wiring gets a "set" from the engine heat and 40 years. You just start plugging in connectors until you are done. I installed a used replacement in 10 minutes and I'm an electrical dummy. If you are buying new from Jeff, he probably labels the wires or gives you a diagram. It always helps to take some pics of he engine compartment before you do anything and as you remove parts.
- Lo-Fi Version Time is now: 11th July 2025 - 11:35 AM
